XOLO a500s IPS or XOLO Q500 OGS
Results 1 to 4 of 4
Thread: XOLO a500s IPS or XOLO Q500 OGS
  1. #1
    Aug 2008
    Default XOLO a500s IPS or XOLO Q500 OGS
    I want to buy a mobile and I have marked down two models
    XOLO a500s IPS
    XOLO Q500 OGS
    I want to know if there is any difference between IPS and OGS.
    I heard XOLO is having bad service.
    Any other phone in this range (budget - 8000 max)
    I don't want Lumia 520 as I need to cut the sim.
    Popular Gadget Deals
    Regards,
    Anand N
  2. #2
    Gaming hardcore pramudit's Avatar
    Dec 2011
    Jhansi
    Default Re: XOLO a500s IPS or XOLO Q500 OGS
    Don't know about OGS, haven't used it personally so can't say. IPS have good viewing angle so you will be able to see display even when you tilt the phone.
    For service, I think it was satisfactory for a small town, they arranged courier to take and delivered at my home. PS - they have service centers in very few places and yes I had to talk to them twice to get my phone picked up.
    Intel Core 2 Quad Q8400 |Asus EAH4350 HD| WD blue 500GB | Intel DG41RQ | 2GB DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
    HP Pavilion G4-> AMD A4 3300MX | 6480G
    steam id- pramudit
    [URL="http://www.thinkdigit.com/forum/chit-chat/151503-diy-coil-gun.html"]My coil Gun[/URL]
  3. #3
    sam
    sam is offline
    Forum Moderator
    Jan 2010
    Guwahati
    no to Q500. It has qualcomm SOC with extremely poor GPU. Other mobiles you can look at Karbonn S2 (under 8k but with 1GB ram & quadcore Cortex A7) or Micromax Juice A77 (1GB ram but dualcore Cortex A7 but 3000mah battery) but heard A77 lacks some sensor.
  4. #4
    Aug 2008
    Quote Originally Posted by sam View Post
    Phonecurry says q500 is an excellent buy over a500s IPS
    XOLO Q500: Handpicked Reviews, Summary & Buying Recommendation | phoneCURRY (India)
    Regards,
    Anand N
