Old 01-11-2005, 06:56 PM   #1 (permalink)
Default W800 vs K750
What's d difference between k750 and W800 ???
and why is w800 expensive compared to k750 ???
SystemError is offline
Old 01-11-2005, 07:58 PM   #2 (permalink)
K750i meant for imaging and it includes only 64 mb meomary card. W800 is for listening music, Here "W" is for walkman. It includes a excellent headphones and 512 mb meomary card.
vishalbhatia is offline
Old 02-11-2005, 03:05 AM   #3 (permalink)
mobilegeek's Avatar
K750i is targeted at imaging .. Camera (2.0 MegaPixel)
W800i is more of a music phone .. with standard 512MB Flash Card
these are the basic diffentiation between the two.
mobilegeek is offline
Old 02-11-2005, 10:22 AM   #4 (permalink)
kumarmohit's Avatar
Flash card or Memory Stick (Pro or Duo) Plz Clarify
kumarmohit is offline
Old 02-11-2005, 10:50 AM   #5 (permalink)
Memory Stick is a type of flash memory - just like MMC, SD, xD, CF, etc. All of them are different types of flash memory ans were made by different companies hence the differences. Don't get confused.
Nemesis is offline
Old 03-11-2005, 11:26 PM   #6 (permalink)
dhan_shh's Avatar
W800i has a sexy orange color,smooth 'joystick',Hi-Fi headset with 3.5mm jack gives a final punch to K750i.
Expect the Unexpected !
dhan_shh is offline
Old 04-11-2005, 12:28 AM   #7 (permalink)
mobilegeek's Avatar
Very true man ... The 3.5 mm jack .. makes it dynamic n campatible to all your regular headphones.. if it had the symbian i would have bought this baby!
Old 04-11-2005, 12:51 PM   #8 (permalink)
Quick Compare Both
Old 04-11-2005, 08:17 PM   #9 (permalink)
SWEET SNEHA's Avatar
@systemerror
U asked the question
and u urself gave the best answer
......lol
"If it weren't for electricity we'd all be watching television by candlelight."
- George Gobel
SWEET SNEHA is offline
Old 06-11-2005, 10:52 AM   #10 (permalink)
Wire muncher!
infra_red_dude's Avatar
hi guys, am back!
ok, some piece of insider info. the k750i and the w800i are same wid some difference in the software. this is the reason why you can safely flash a k750i wid w800i firmware (this has been tried and tested successfully!)
so, the w800i is nothing but a rebadged version of k750i wid some cosmetic changes (like the walkman button, cam cover etc.) and 512mb memory stick duo.
infra_red_dude is online now
Old 06-11-2005, 07:36 PM   #11 (permalink)
Location: don't drink and drive you might spill your beer
Hey, infra are u sure we can flash w800i firmware over k750i? I'll be risking my mob, otherwise. I chose k750 over w800 only 'cos it has a sleek executive finish unlike w800's funky orange.
pakkasir is offline
Old 06-11-2005, 09:51 PM   #12 (permalink)
Wire muncher!
yep dude, but be forwarned that you'll lose any kinda warranty! you'll need the cable, flasher utility and the compatible flash files. also there are 2 w800i firmware versions: one red and one brown. check which is compatible wid ur k750i based on the locale and the firmware version. get all ur facts right before you jump!
check these links:
http://myforum.lasyk.net/showthread.php?t=20279
http://myforum.lasyk.net/showthread.php?t=19292
http://myforum.lasyk.net/showthread.php?t=18620
http://forums.se-nse.net/index.php?showtopic=1846
http://forums.se-nse.net/index.php?showtopic=1870
http://www.davinciteam.com
ps: this procedure if done incorrectly will screw up ur phone. plz be forewarned. if you aint sure wot u are doing, then BACK OUT!
one more thing, except a few software tweaks and walkman mode you get nothing extra by converting it into w800i as both phones are same!!!
Old 07-11-2005, 12:28 AM   #13 (permalink)
thanks 4 the link. But, I guess i'll remain content with my firmware
pakkasir is offline
Old 07-11-2005, 10:27 PM   #14 (permalink)
sagar_coolx's Avatar
w 800i's da betta 1.
with it's gr* audio capablities,it can function as a complele portable entertainment phone
sagar_coolx is offline
Old 08-11-2005, 01:47 AM   #15 (permalink)
Aniruddh's Avatar
i feel 750k is a betta choice.no doubt w800 is a very gud cellfone but 750k is my choice.
Aniruddh is offline
Old 08-11-2005, 01:57 AM   #16 (permalink)
dIgItaL_BrAt's Avatar
the k750i's audio capabilities are'nt bad either.
dIgItaL_BrAt is offline
Old 08-11-2005, 03:31 AM   #17 (permalink)
mobilegeek's Avatar
Although I like Nokia .. but
K750i Black ... certainly has killing looks
Old 08-11-2005, 07:00 AM   #18 (permalink)
Wire muncher!
w800i's no different. some cosmetic changes, a bundled 512mb stick and 3.5mm phone jack.
but yes, k750i looks more professional!
Old 14-05-2006, 10:59 AM   #19 (permalink)
Default Re: W800 vs K750
Guys I have a doubt,
Is there any possibility of using W800 or W810 Earplug with K750i ?
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
