Old 01-11-2005, 10:16 AM   #1 (permalink)
champ_rock
champ_rock's Avatar
Default NOKIA PC SUITE
is there any alternative to NOkia PC Suite
Registered Linux user number 400618
champ_rock is offline
Old 01-11-2005, 12:21 PM   #2 (permalink)
Oxygen phone Manager but PC Suite 6.6 is not bad.
vishalbhatia is offline
Old 03-11-2005, 08:30 AM   #3 (permalink)
champ_rock
champ_rock's Avatar
actually the prob is that it is not detecting 6610......
it detects 6630 fine.................
Old 03-11-2005, 09:35 AM   #4 (permalink)
kumarmohit's Avatar
I am not sure but this might be if you are using PC suite version not meant for 6610 as there are optimsed version for every kind of fone -- you have to download the 6610 version from Nokia website..
kumarmohit is offline
Old 03-11-2005, 10:24 AM   #5 (permalink)
Oh so you tried to connect 6610 with dku2 cable which comes with 6630! Iam right? Please note that 6610 will only work with dku5 which costs you about 1900 bucks! So your prob is solved I think.
Old 03-11-2005, 12:19 PM   #6 (permalink)
champ_rock
champ_rock's Avatar
yeah DKU2 onnly........ will not spend 1900 for that...... thanks any ways
Old 03-11-2005, 12:38 PM   #7 (permalink)
Champrock, what apps you installed in your 6630?
Old 03-11-2005, 12:44 PM   #8 (permalink)
champ_rock
champ_rock's Avatar
oxford dictionary
norton antivirus
counter strike
midtown maddness
fe explorer.
flight game
and many tthemesssssssssssss
Old 04-11-2005, 12:47 PM   #9 (permalink)
sidewinder's Avatar
are yaar get an usb ti infrared adapter..costs around 200 bucks...ur problem will be solved;.
Bombina rocks
sidewinder is offline
Old 04-11-2005, 01:33 PM   #10 (permalink)
champ_rock
champ_rock's Avatar
actually my 6630 does not have infrared and 6610 does not have bluetooth.........
so the common thing is a dta cable nly
Old 04-11-2005, 07:12 PM   #11 (permalink)
sidewinder's Avatar
u already told that u have the cable for ur 6630....
Bombina rocks
Old 04-11-2005, 09:02 PM   #12 (permalink)
champ_rock
champ_rock's Avatar
no i wanted somethhing that would connect both... but unfortunately that cannot happen......
Old 05-11-2005, 10:37 AM   #13 (permalink)
Yes, this is the cheapest answer to your problem!
Old 06-11-2005, 03:14 AM   #14 (permalink)
18 Till I Die............
But vishal he's already mentioned that his 6630 doesn't have infrared. SO, i guess there's no one stop soln. to this as he's himself admitted or is there?
mehulved is offline
Old 06-11-2005, 03:55 PM   #15 (permalink)
Wire muncher!
infra_red_dude's Avatar
hey a good alternative to pc suite is Float's mobile agent. it has been specifically designed for SE phones but works well wid popular nokia sets.
http://fma.sourceforge.net
infra_red_dude is online now
Old 07-11-2005, 08:42 AM   #16 (permalink)
is there any alternative to connect to internet other than pc suite??
geforce4 is offline
Old 07-11-2005, 09:57 AM   #17 (permalink)
kumarmohit's Avatar
oxford dictionary
Does this dictionary work on fone or does it need GPRS
counter strike,flight game
Plz give more details as in the proper name as shown in the about dialog
If possible publisher too
