Old 30-10-2005, 11:55 PM   #1 (permalink)
jiteshbhimani's Avatar
Default Which one is better .OGG or .MP3??
friends, i want to know which format is better for playing songs on Nokia 3230. .ogg or .MP3?
Is there any difference between the two? I read some where that .OGG files sounds better and are much more compressed i.e small in size.
Jitu........................
jiteshbhimani is offline
Old 31-10-2005, 02:26 AM   #2 (permalink)
mobilegeek's Avatar
.ogg files sounds better n louder at lower rates
and
thereby .ogg files are small in size
Which software i should use to improve the sound quality as well as hear it loud and clear for Nokia 3230?
Certainly Ogg Player
Next time dont post two threads.
mobilegeek is offline
Old 31-10-2005, 10:57 AM   #3 (permalink)
gxsaurav
Posts: n/a
I would say, go for 64 kbps MP4 with 44.1 KHz sample rate, that will be enough & will also sound good on mobiles
Old 31-10-2005, 02:17 PM   #4 (permalink)
tuxfan's Avatar
If you have an OGG player, go for OGG. Its a free open file format and will never be copyrighted/patented. Contrarily, MP3 will be restricted some day.
For some similar reason, Red Hat 9 didn't include MP3 compatibilty and it required some download and installations for MP3 to work under it.
dbPowerAmp Music Convertor has stopped giving facility to convert to MP3 due to some legal issues. The older versions have this facility, newer ones don't have it
tuxfan is offline
Old 31-10-2005, 08:16 PM   #5 (permalink)
Its all upon you. You can play either in ogg or mp3, both will give you the same results. You can use oggplay for playing ogg files in 3230. Download it from "http://sourceforge.net/projects/symbianoggplay". To convert music from mp3s to ogg you can use ogg encoder plugin for winamp. You can download it free from winamp(dot)com.
vishalbhatia is offline
Old 31-10-2005, 09:10 PM   #6 (permalink)
kumarmohit's Avatar
Oggplay will play both but even this months fasttrack claims that OGG format is better
kumarmohit is offline
Old 31-10-2005, 09:53 PM   #7 (permalink)
mobilegeek's Avatar
Actually I mean .. Oggplay ... the Freeware only
Its a must have on every Symbian
Download the Ogg play 1.6.2 ... from this link
http://sourceforge.net/project/showf...ease_id=277161
Old 31-10-2005, 10:07 PM   #8 (permalink)
Thanx dudes for replying,
I also some how feel that .OGG file is better than Mp3.
But, i have a little query can we set .ogg file as ring tone in NOKIA 3230 and if not then is there any application which helps us in doing so?
Old 01-11-2005, 02:49 AM   #9 (permalink)
mobilegeek's Avatar
Yes you can .. no application required.
