Old 29-10-2005, 11:47 PM   #1 (permalink)
jiteshbhimani's Avatar
Default Listen To Radio without enhancement?
Hi guys,
I want to know whether it is possible to listen to radio using buit in speaker of the phone without attaching the enhancement??
I got NOKIA 3230.
Is there any application available for that??
Jitu........................
jiteshbhimani is offline
Old 30-10-2005, 12:39 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
I tried the same thing once in Nokia 2100...
I tried to connect the points where the headset is attached by a thin WIRE and it worked but u'll not get the good signals bcoz the headset works as the anteena for radio.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-10-2005, 04:18 PM   #3 (permalink)
You need to short-circuit the POP port but as Vishal said you won't get good radio signal as radio serves as antenna for radio.
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
