Old 27-10-2005, 12:51 AM   #1 (permalink)
Default samsung users please help
FOR ALL SAMSUNG USERS,i have a samsung x100 mobile phone .can i use it to browse internet in my computer using airtel gprs.what are the software and hardware needed.I HAD EARLIER POSTED THIS QUESTION in the general section,but due to lack of response i am posting this on the mobile section.thank u.
tintin is offline
Old 28-10-2005, 11:27 PM   #2 (permalink)
Default anyone having samsung mobile please help
does no one here have a samsung mobile,a c100 would do.can i browse internet on my computer using my samsung X100 and airtel GPRS.I repeat on my computer not on my wap browser.please please help.
tintin is offline
Old 29-10-2005, 01:25 AM   #3 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
YES U Can..
i do the same
no need 2 dwnld any sw.. buy a datacabl... the cd which comes with it has the sw.
call airtel cust. care and inform them...
4 hrs latr n joy...
aku
aku is offline
Old 29-10-2005, 08:33 AM   #4 (permalink)
mobilegeek's Avatar
Default Re: anyone having samsung mobile please help
Hey dude ... sometime you have to wait to get correct response.
As far as answer to your query:
I can tell you the solution to you bcoz.. have been through a similar incident
Yes you can very much use it ... many of us are using it
as for me bcoz of edge .. I get good speed too.
To use the phone for internet..
You must have modem in phone .. which it has,
secondly you can connect through either InfraRed or DataCable
and thirdly, you have to activate the GPRS ..
Tell the customer care that you want MOBILE-OFFICE
Save the settings for the same in the phone.
In some places you need to have post-paid connection
That you need to check..
Tell me where you are located n service you use
Ask exactly what you want to know .. we will tell you the
solution
mobilegeek
mobilegeek is offline
Old 29-10-2005, 01:32 PM   #5 (permalink)
thank u both,i am sorry that i was in a hurry.i am located in orissa.i asked the customer care and they told that they do offer airtel mobile office for 99 bucks a month.will a normal data cable through which we send ringtones and wallpaper will do or i have to get a specific for browsing internet.will u both mind if I PM U if i have some other doubts later because i have not bought the datacable and i think i might have problems installing it.the problem is that where i live no one uses data cable for internet.Neither the shopkeepers know much about it.do reply
tintin is offline
Old 29-10-2005, 10:14 PM   #6 (permalink)
mobilegeek's Avatar
No prob you can pm..
but confirm one thing from customercare ... that they are offering you AIRTEL MOBILE OFFICE for 99only
Old 30-10-2005, 11:32 PM   #7 (permalink)
hey mobilegeek,do i need a specific data cable for connecting my samsung phone.I have gone through the forum and saw that many nokia phones need different data cables.is there any configuration for samsung data cables.
tintin is offline
Old 31-10-2005, 02:09 AM   #8 (permalink)
mobilegeek's Avatar
There is no such problem with Samsung x100,
when you buy the cable just check that it is working with your phone.
also
remember that you need to download software from samsung site
http://www.samsung.com/in/support/pr...el_Select.aspx
Old 31-10-2005, 07:10 PM   #9 (permalink)
Walking, since 2004.
mail2and's Avatar
You need Easygprs that comes with easystudio...
download it from the link mobilegeek gave...
otherwise for just gprs... u can configure using the built-in dialer in windows.
Mumbai, I miss you. :(
mail2and is offline
Old 01-11-2005, 12:07 AM   #10 (permalink)
ok my postpaid connection is'nt available yet.they are telling some prob. in my documents.i will try when i get it and get in touch with you again.
tintin is offline
