Sony Xperia M/M Dual discussion - Page 7
Page 7 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 181 to 210 of 448
Like Tree1Likes
Thread: Sony Xperia M/M Dual discussion
  1. #181
    Human Spambot Nerevarine's Avatar
    Feb 2011
    Bhubaneshwar, Orissa, India
    Default Re: Sony Xperia M/M Dual discussion
    should have ordered from ebay
    Popular Gadget Deals
    ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
  2. #182
    Firecracker to the moon theserpent's Avatar
    Nov 2011
    Mangalore
    Quote Originally Posted by mohit9206 View Post
    But will XM get 4.4 kitkat considering their poor update record for example xperia sola ?
    Sony has a good track of updating
    @random I think X.L/X.M will receive 4.4
    Hmm
  3. #183
    Feb 2011
    Can someone upload the stock wallpapers and music that came bundled with the device ?
  4. #184
    In The Zone mikael_schiffer's Avatar
    Jun 2004
    Pandemonium
    Quote Originally Posted by Nerevarine View Post
    The sellers giving it away for Rs12,000 have removed themselves from listing ever since the price hike happened
    And the only ones available now are priced at Rs14000+ (updated price)
    I wanted to go for Flipkart but Infibeam was cheaper by Rs700
    .. hmm anyways i can wait. Local shops sell it for Rs14,500.
    ( ͡ ͜ʖ ͡)
  5. #185
    Feb 2011
    then you made the right decision .. As long as there's CoD, you will be absolutely fine..
  6. #186
    Active on Several Forums kartikoli's Avatar
    Mar 2011
    Lucknow
    How can we install games on sd card?
  7. #187
    Feb 2011
    Swap SD card to internal memory and install on internal memory.. IDK how many times i have to repeat this lol..
    I have installed Dark Knight rises whose total size is more than 2 GB, it would have been impossible on normal internal memory
  8. #188
    Mar 2011
    Lucknow
    please repeat it once more ... how to do it
  9. #189
    Feb 2011
    Use Motochopper or Framaroot to ROOT your device first.. This will give you partial root access..
    Then download BusyBox and install it.. This will give you COMPLETE root access ..
    Then Download reboot remount fix for xperia devices.. After using this, the RW mount reboot issue will be resolved..
    Install Script manager
    Then download a custom made script from XDA to remount SD card as internal memory everytime your device boots.. (If you want to revert changes, just uninstall scriptmanager)
    [Resolved] (guide xperia m) rooting , reboot fix, and swapping internal memory - xda-developers
    Follow this guide..itll clear things up.. Do exactly as the guide states otherwise you might softbrick your device..
  10. #190
    Mar 2011
    Lucknow
    Thanks brother
  11. #191
    Nov 2011
    Mangalore
    Mom bought the X.M
    Hmm
  12. #192
    ZTR
    ZTR is offline
    Rookie Techie ZTR's Avatar
    Mar 2013
    Mumbai
    If am not wrong M doesnt have a locked BootLoader??
    [B]Phenom II X4 955 BE | Gigabyte 970A-DS3 | Cooler Master Hyper 212 Evo | 2x2 GB Kingston DDR3 RAM 1333 MHz OC'ed to 1600 MHz | Sapphire 5670 HD | WD Blue 500GB | Corsair VS450 | Cooler Master Elite 335U |[/B][B]Samsung Galaxy S I9000 Running CM 11 (4.4.2) [/B]
  13. #193
    Feb 2011
    It does, but you can still gain full root access even with locked bootloader..
    Same with Xperia L
  14. #194
    keen to learn..
    Mar 2010
    Amritsar
    one of my friend, who owned XM 3 weeks ago, today complaint that, its getting warm ,while talking more than 20 mins and battery doesnt last even a full day while 2G is always on.
    Samsung C3322 Duos
    Bajaj Discover 100T
  15. #195
    Nov 2008
    Kerala
    Hello all , Can any Xperia L user post Screen shot of PDF reader viewing below pdf
    edit - Single Page text PDF document is 500kb which is above forum supported upload limit
    Kindly view Screen short of any Ebook text in landscape & Normal
    or if outside link is ok
    Mastering_Windows_7_Deployment1.pdf
    Also is there any new Phone with Bigger screen (non-indian)& JB+ support ?
    i am heavy ebook/pdf book reader while on travel,planning to replace HTC explorer
    AMD Phenom II X6 1055T ,Benq G2220HD 22 ,GIGABYTE GA-880GM-UD2H ,COOLER MASTER Elite 310 ,CORSAIR 2GB 240-Pin DDR3 X3[6GB] , FSP Saga II 500 W HD 5750 . Hyper 212+ OS :Win 7 64 bit
  16. #196
    Feb 2011
    Quote Originally Posted by a2mn2002 View Post
    Phone does get warm if u play graphics heavy games.. and regarding the battery issue, i have to say BS on that one.. My phone is connected to wifi most of the time which is supposed to be more of a battery hog than 2G and it easily lasts a day..
  17. #197
    ZTR
    ZTR is offline
    Mar 2013
    Mumbai
    Umm data consumes more than WiFi
  18. #198
    Jun 2004
    Pandemonium
    Dude, thats a very lengthy process.. How about one click root solutions like these- How to Root Sony Xperia M C1904 / 1905 using One-Click Root solution
    Is there a video tutorial?? Dont wanna destroy a brand new phone
    ( ͡ ͜ʖ ͡)
  19. #199
    In The Zone mohit9206's Avatar
    May 2013
    Mumbai
    Quote Originally Posted by theserpent View Post
    Mom bought the X.M
    Congrats.But isnt android useless for elder people as its too complicated for them assuming your mom isnt to well versed with technology ?Wouldnt WP been better ?
  20. #200
    Feb 2011
    Quote Originally Posted by mikael_schiffer View Post
    I tried One Click Root, it didnot work.. Rooting will fail.. I think it requires unlocked bootloader..
    The process isnt that difficult.. just follow the instructions and you are fine
    Even if you manage to SOFT BRICK your phone, I have a backup image of the device ready and uploaded to my dropbox.. just flash it via flashtool and your phone will be as good as new
    Latest update released for Xperia M.. Will download ASAP
  21. #201
    ZTR
    ZTR is offline
    Mar 2013
    Mumbai
    Do tell if something is new
  22. #202
    Apprentice vikash's Avatar
    Nov 2011
    ranchi
    I got a 7.5% off coupon from reliance recharge.
    However I am unable to pair it up with XM http://www.ebay.in/itm/Sony-Xperia-M...ht_3489wt_1271
    Do you guys have any idea why?
    Any other alternatives to get some discounts out of ebay??
  23. #203
    Feb 2011
    Installed the new update..I have yet to find any thing different.. Perhaps they have improved the camera a bit, i cant really tell..
    Need to tinker around a bit more..
    BTW updating will remove ROOT and will remove SD swap.. I had to do it all again :/ So it's better to first update, then root your device
  24. #204
    Nov 2011
    ranchi
    Good news for those waiting for Xperia M. Its again in stock and that too at normal pricing.
    Was tired of waiting for the dual SIM variant, ordered my single SIM version from
    sony xperia m | eBay
    Hurry up!!!
    And nevarine, which m/y card are you using with your Xperia M ?
  25. #205
    Being Human shreymittal's Avatar
    Aug 2012
    Mathura -->> NCR
    Got mine X:M but handed over to my sis
    [url=http://www.speedtest.net/result/3174273798.png]My Speedtest Result[/url] | [url=http://s1285.photobucket.com/user/shreymittal/library/My%20iems]SoundMagic E10[/url] | Sony MDREX220LP
    E7500 | G41M-ES2L | 4GB | 500GB | HD4360 | A520 5.1 | Samsung SyncMaster 22" | XPERIA C | LENOVO TAB A3000 | XPERIA M | XPERIA L | TP-Link W8961 | TP-LINK TL-WR740N | Windows 7 HB | Ubuntu 12.04
    Vaio VPCEB36FG : i3-370M | 4 GB | HM55 Express Chipset | 500 GB| HD 5650 | Windows 7 HP
    Steam : [url=http://steamcommunity.com/profiles/76561198042992568/]shreymittal[/url]
  26. #206
    Feb 2011
    Quote Originally Posted by vikash View Post
    Hurry up!!!
    Im using a Transcend Class 10 8 GB microSD.. It mounts up really fast.. Id recommend a class 6 atleast
    UPDATE: I might be wrong but i believe autofocus and color reproduction has slightly improved with the update.. I will test it side by side with a stock Xperia M soon
  27. #207
    Nov 2011
    ranchi
    Thnx i'll get d Class10 Sandisk or Transcend
    Yummy!!!
  28. #208
    Human Spambot randomuser111's Avatar
    Jul 2011
    @Nerevarine
    Can you try this Camera app and report on any difference in image quality ? It should bring about a good improvement in quality.
    Lenovo Super Camera.apk
    Just download and install apk
  29. #209
    Feb 2011
    All right, doing it right away
  30. #210
    Human Spambot Zangetsu's Avatar
    Jan 2008
    Soul Society
    how to move apps to SD in Xperia M?
    i install app2sd but its not working?
    HTC One V | Nikon D3100 | Apple Ipod Touch 4G | SM ES18 | Casio Edifice EX106 | WD My Passport 1 TB | Seagate Backup Plus Slim 500GB
