[ISSUE] Micromax A116 Canvas HD - Headphones compatibilty problem
Results 1 to 5 of 5
Thread: [ISSUE] Micromax A116 Canvas HD - Headphones compatibilty problem
  1. #1
    Jan 2012
    Exclamation [ISSUE] Micromax A116 Canvas HD - Headphones compatibilty problem
    So, guys, I bought the new Canvas HD (Micromax A116) ...
    Everything is very well exceeding my expectations except two issues (one minor, one major)
    Minor - GPS has problems latching onto a satellite. Can be fixed with some booster apps, I guess. There are youtube videos out there explaining the process (Haven't tried them yet)
    Major - Any headphones other than the stock ones provided in the Box with the phone, do not run properly with this device.
    I mean, I tried HTC stock ones, Samsung stock ones, my Pioneer Headset, all were giving a very muffled output (I was watching a movie and the dialogues ONLY were muffled, often almost muted, but the background scores were sounding normal, glorious as ever)
    When I tried the stock ones, everything was fine. But these are of low-grade make, and hence wanted to use other better-quality ones.
    Anyone who has a solution / suggestions?
    Popular Gadget Deals
  2. #2
    Peak Oil is real! AndroidFan's Avatar
    Feb 2011
    Default Re: [ISSUE] Micromax A116 Canvas HD - Headphones compatibilty problem
    Quote Originally Posted by rachitsaran View Post
    This is a very strange problem... Hopefully, some member will be able to help you out...
    You have posted this query on XDA too... in the wrong category though... Lets see... Keep an eye on that thread...
    Daily Driver -- Galaxy Nexus Cyanogenmod 11 Nightlies
  3. #3
    Jan 2012
    yeah ... didn't see that the category was "Hardware Hacking" and not "Hardware"
    Waiting for some admin to correct it ...
  4. #4
    not a newbie..... papul1993's Avatar
    Apr 2009
    Assam
    Try using a normal stereo headphone. Not a stock headset of another manufacturer that has inbuilt mic too. See if that works.
    [SPOILER] Nothing to see here. I am a poor guy with a very basic computer.[/SPOILER]
  5. #5
    May 2013
    Quote Originally Posted by AndroidFan View Post
    the solution is that u take the cell phone and try out headsets in the market ... thats because the 3.5mm pin of this headset is a little bit longer than the usual 3.5mm pins..... believe me... measure it and see..... so u will have all the other headsets on one side and this one on the other side with its pin being just 1-2 mm longer
