Old 20-10-2005, 08:59 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Default How to hide SMS in 6600?
i have nokia 6600.
1. how do u install .sis and.jar applications?
2. i have mumSMS . it can password protect my SMS's ..but problem is that Nokia 6600 itself has Messaging folder..if I delete some SMS from Messaging Folder , mumSMS also deletes it automatically...
Also one can read SMS by going to Messaging folder...How do I add password on that?
or can I delete Messaging folder but mumSMS doesnt have option to create new SMS......
3. How one can encrypt/hide .3gp files ?
TIA
Sumit
esumitkumar is offline
Old 21-10-2005, 09:45 AM   #2 (permalink)
thrash_metal's Avatar
For installing *.sis files u need to send them to your phone . Either use a Bluetooth , Ir or a cable .. If u have a cable then u can directly install them to your phone using the nokia Pc Suit application . If you send them through bluetooth then you will find them in your msg inbox as a msg .. just open the msg and install !!!!
Dunno about the encrypting in your inbox thing .. ill post as soon as i get any info on thet one !
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
