Samsung Tab 2 wifi problem
Results 1 to 13 of 13
Thread: Samsung Tab 2 wifi problem
  1. #1
    Jan 2013
    Default Samsung Tab 2 wifi problem
    hello there,
    i have bought a Samsung tab 2 but it has problem with wifi whenever i try to download internet stops and starts .Many tab 2 users have wifi problem so please tell me how to fix this issue.
    thank you.
    Popular Gadget Deals
  2. #2
    Being Human shreymittal's Avatar
    Aug 2012
    Mathura -->> NCR
    Default Re: Samsung Tab 2 wifi problem
    Quote Originally Posted by infodevz View Post
    hello there,
    thank you.
    Try updating your firmware see if that helps.
    But I dint found any problems in my brothers tab 2 while downloading via WiFi he is using jellybean BTW which Android version you are on.
    [url=http://www.speedtest.net/result/3174273798.png]My Speedtest Result[/url] | [url=http://s1285.photobucket.com/user/shreymittal/library/My%20iems]SoundMagic E10[/url] | Sony MDREX220LP
    E7500 | G41M-ES2L | 4GB | 500GB | HD4360 | A520 5.1 | Samsung SyncMaster 22" | XPERIA C | LENOVO TAB A3000 | XPERIA M | XPERIA L | TP-Link W8961 | TP-LINK TL-WR740N | Windows 7 HB | Ubuntu 12.04
    Vaio VPCEB36FG : i3-370M | 4 GB | HM55 Express Chipset | 500 GB| HD 5650 | Windows 7 HP
    Steam : [url=http://steamcommunity.com/profiles/76561198042992568/]shreymittal[/url]
  3. #3
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    hello there,
    thank you.
    What did you try to download BTW?
    Follow me on Twitter:http://twitter.com/wuodland
    Have a look at my Photography page: http://bit.ly/N2aMTi
  4. #4
    Geek in making $hadow's Avatar
    Feb 2013
    hakkuna mattata
    hello there,
    thank you.
    I don't agree with that may be you can have a manufacturing defects. I am having tab2 and mine is working fine. Try to exchange it if you can or try to update the firmware.
  5. #5
    Jan 2013
    the tablet is not defective because i have taken it to my office and it is working well there so problem is in my wifi settings and i am running andoird 4.1
  6. #6
    Aug 2012
    Mathura -->> NCR
    I think...the problem is with your router are you getting same problem with another devices too. What were you downloading??
  7. #7
    Jan 2013
    my iPhone , laptop working great with my router and i am just downloading google apps in my tablet....
  8. #8
    Aug 2012
    Mathura -->> NCR
    Try this delete your WiFi network in your tablet and then re-connect WiFi network again
  9. #9
    Jan 2013
    i have already done that many times not working , its like in a 5mb app 2.5mb download and stops for a min. and than a message comes connected to wifi than downloading starts again .... anyone know how to delete wifi settings from folder or files
  10. #10
    Aug 2012
    Mathura -->> NCR
    Specifically only that app is having problem.
  11. #11
    Jan 2013
    all the apps stops and starts while downloading and same with browsing any website ......
  12. #12
    Aug 2012
    Mathura -->> NCR
    last time try hard reset
  13. #13
    Mar 2012
    hello there,
    thank you.
    I dont think it is a tab 2 related problem but kind of a Samsung problem in some networks. I had the same problem with my S3 in my office network. Was not connecting to wifi. I went into advanced settings and changed profile from dynamic to static, manually inputted the ip addess, and it has never stopped working ever since. Hope this helps
