Old 14-10-2005, 03:58 AM   #1 (permalink)
Default Anyone using a 1GB RS MMC with a NOKIA 7610
I'v ordered for a 1 gb rs mmc , anybody using it??
I wanna know if the phone hangs up on the card??
Life sucks loosers dry,if u wanna f#@k with the eagles u have to learn to fly !!
beaditya is offline
Old 14-10-2005, 10:42 PM   #2 (permalink)
mobilegeek's Avatar
Not sure about that .. but for 7610 it is suggested that dont put more than 512MB!
So, You got to check.
Between How much is the Price!
mobilegeek is offline
Old 15-10-2005, 08:39 PM   #3 (permalink)
thrash_metal's Avatar
yeah according to what i have heard from people ... even 512mb hangs up the phone . A frnd used to work in a mobile shop told me that he had sold a 512mb and the customer came back complaining that the phone hangs a lot .
well keep me posted how it turns out for your phone .
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 15-10-2005, 09:27 PM   #4 (permalink)
mobilegeek's Avatar
thrash_metal
Can you get me the price of DV MMC - KINGSTON for 6630?
Old 15-10-2005, 09:39 PM   #5 (permalink)
arre that dude used to work there .... leme c what i can do here ........ give a few days !!!
Old 15-10-2005, 10:05 PM   #6 (permalink)
mobilegeek's Avatar
No probs .. at all
But plz make sure you are getting the rate of DualVoltage RS MMC
Kingston make.
Old 19-10-2005, 05:52 PM   #7 (permalink)
well i couldnt get hold of the price of the 1Gb but 512mb is there for 2500/-
Old 20-10-2005, 12:14 AM   #8 (permalink)
100% sure..ur phone hangs up with 1Gb card. C'mmon man..its not a pc with a hard drive! The processor @ the max supports 512...thats the max/worst case. Dont go more than that...its a sheer waste of money. Think abt it pal...i hav a friend who did the same mistake and pondering over it!
prash007 is offline
Old 20-10-2005, 02:37 AM   #9 (permalink)
I got the 1 gb rs mmc, till now its workin fine .........................its 87$ with the shipping
I'm just lookin for a good convertor for all my videos...................can anyone tell me how i can convert avi and wma to real media??
beaditya is offline
Old 20-10-2005, 03:07 AM   #10 (permalink)
mobilegeek's Avatar
beaditya
Smart Movie Converter ... is good .. it convets into a very small size file..
and
How much did you paid for card, .. and does it really not hang the phone?Which make is it?
Old 20-10-2005, 03:19 AM   #11 (permalink)
kumarmohit's Avatar
@ beaditya
You can get Real Producer Basic from realnetworks.com for free
but I have been trying movies in RM and suggest that u better try 3gp as its a mobile phone native format and shall be about as light as rm but will have a slight edge in quality for this you shall have to look for nokia multimedia converter which is free ( u've to register on their forum tho) or u cam try Imtoo 3gp converter from imtoo.com
kumarmohit is offline
Old 20-10-2005, 09:35 AM   #12 (permalink)
mobile geek is right .. use smartmovie .. its the best and worth the price tag for that software ! Even if you just get the player on ur phone softwares like virtual dub can also convert movies for your phone (and remember to resize before compressing it ) ... ps: thats the way i get through my lectures in college ! and remember to increase the sound level during compression to atleast 150 so that you get a good amount of sound ,, above 250 and stuff it begins to crack up and jar !
Dont convert to real media or something ... use smart movie ! with the 1Gb card you can put like 5 movies in it and still have enough memory to put songs and stuff in . 1 movie will be like 100 - 120mb !!
Old 20-10-2005, 11:33 AM   #13 (permalink)
gdatuk's Avatar
i use a 512 and it is 1400Rs in chennai..working just fine...but a bit slow...but never hangs...model is 6670
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 20-10-2005, 11:37 AM   #14 (permalink)
champ_rock
champ_rock's Avatar
is it original prices... or grey market
Registered Linux user number 400618
champ_rock is offline
Old 21-10-2005, 09:59 AM   #15 (permalink)
@beaditya
Howz the card working so far ??? If its good even i might consider going for it !! Where did you order it from ? ebay ?
Old 22-10-2005, 01:56 AM   #16 (permalink)
@gdatuk...
is ur 512 a rs mmc or jus an ordinary mmc? and where did u get it in chennai? grey...?
prash007 is offline
Old 23-10-2005, 11:04 PM   #17 (permalink)
mobilegeek's Avatar
Originally Posted by prash007
@gdatuk...
In 6670 ... it has to be Reduced-Size mmc ..
big mmc will not fit in that!
Old 24-10-2005, 07:08 AM   #18 (permalink)
oh ok...thanx for the info pal.
prash007 is offline
Old 03-11-2005, 12:53 PM   #19 (permalink)
my phone never hung up on my card till date, I'm in chicago, i ordered it from buy.com got it for 72$
Yes i'm using smart movie now !!, watchin full length movies on it !!!!..............its a great player !!!
if anybody needs it , PM me .
@ kumarmohit ...........can u tell me wats the bitrate or frequency or whatever u convert at , b coz the audio i convert using real producer dosnt work on my phone !!!!!!!!!!
beaditya is offline
Old 04-11-2005, 12:33 AM   #20 (permalink)
mobilegeek's Avatar
For video files .. the smart movie converter .. rate 96kbps-150kbps .. n check for reduce frames .. it converts automatically to 208x176
You are using smart Movie .. so you must be familer with that
For audio files use .. dbpoweramp .. n format ogg-vorbis .. trust me its good.
rate 48-64kbps
Old 04-11-2005, 06:58 AM   #21 (permalink)
rate 48-64kbps
but I will need a player to play ogg files !!
how do u convert mp3 into real audio to play on 7610
beaditya is offline
Old 04-11-2005, 07:44 AM   #22 (permalink)
mobilegeek's Avatar
Oggplay its a freeware .. Dont need to install anyother cr@p .. just use this
& note Dont install unnecessary applications in the phone
I dont need real media .. why do you need that for?
bcoz I just use the .ogg files or acc files, you can make them ringtones too ..
.ogg is the best format for mobile it minimises the size at 64kbps(no-need for higher bitrate) .. the best thing its free .. no - license prob
Official Page: http://symbianoggplay.sourceforge.net
Download Link: http://sourceforge.net/project/showf...ease_id=277161
