Old 14-10-2005, 12:56 AM   #1 (permalink)
Default CAn't connect using nokia pc suite
I bought a new bluetooth dongle. with it I installed BlueSoleil 1.6 which was given with the CD given with it. I can work through it and send and receive files with it. But the Nokia Pc suite software which I got with my N6600 is not showing any bluetooth ports and it is not detecting my phone. It is only showing infrared port. And if in Nokia Connection Manager if I try to press bluetooth it is giving error:
"Media type is not supporte. check your system for media settings"
Somebody told that this is done as some other applications has blocked the bluetooth ports. How can I get funtion my Nokia pc suite so that it recognise my N6600.
robogeek is offline
Old 14-10-2005, 10:21 PM   #2 (permalink)
din
Tribal Boy
din's Avatar
You are having the same problem I had !!
In Win XP it may work automatically , you need not install the drivers in that CD
And check these links , you will be able to make it for sure (thanks to Ricky)
http://www.thinkdigit.com/forum/viewtopic.php?t=20261
and
http://forum.gsmhosting.com/vbb/show...hreadid=179871
Good Luck
din is offline
Old 15-10-2005, 12:59 AM   #3 (permalink)
Default n6600
I had same problem.But now it has solved .
Firstly, start BlueSoleil software, search for your phone then go to Tools->Configuration->Quick Connect and see which port is assigned to your phone. If not, assign a port. In "My services"->Properties,make sure that "serial Port A" and "serial port B" are enabled.
Now shutdown BlueSoleil Software and also Bluetooth service. Start N6600 PC Suite. On the taskbar, right click on the mRouter icon and select "properties".Select all ports which are virtually created by Bluesoleil Installation program. Now start Bluesoleil Software and search for your phone. Then right click on your phone icon and press "Refresh Services". Now again start N6600 PC Suite and wait till you get green-blue mRouter icon(30 seconds) in the taskbar.If not, go to BlueSoleil software and right click on the phone icon and select connect->Bluetooth Serial port service. It should work here. Otherwise logoff and try this procedure again. :roll:
My IVT BlueSoleil version is 1.4.9.5
By the way, windows xp was not able to detect my Bluetooth Adapter automatically .
alanpaladka is offline
Old 15-10-2005, 05:50 PM   #4 (permalink)
ThankYou it worked
robogeek is offline
