Results 1 to 2 of 2
Thread: Strange problem with data cable
03-12-2012, 12:48 PM #1
Hi, I have a Nokia X2-00. I have two data cables- the original Nokia cable which came with the phone (CABLE A) and another cable which I bought from a shop (CABLE B). Whenever I connect my phone to my pc with the newer cable (CABLE B), the data transfer stops after about 10 seconds (both in Nokia mode and in mass storage mode). However, the device functions perfectly with the original Nokia cable (CABLE A) which came with the phone. Surprisingly, the other cable (CABLE B) works with the shopkeeper's phone on his PC, so why is that cable not working properly with my phone on my PC? I've tried by attaching the cable in all ports of my PC but it didn't made a difference. Also, my USB ports are functioning perfectly as I regularly use other devices on them.
Please suggest a solution or the problem.
thank You.Intel i3 2100 3.1GHz | 2x2 GB DDR3 RAM 1333 MHz | Intel DH61WW | Seagate Barracuda 500 GB | Corsair CX430v2 | Zebronics Oval | LG 22" HD | Logitech KB mouse combo | Seagate Extension 500 GB portable HDD | APC 600 VA UPS | Philips SHP 2000
Join TDF IRC channel at http://webchat.freenode.net/?channels=krow or use client: server: irc.freenode.net port: 6667 channel: krow
03-12-2012, 05:24 PM #2
Re: Strange problem with data cable
The cable might be bad. Anyways see if using this software helps copying through the bad cable
Download TeraCopy 2.27 - FileHippo.com
Follow me on Twitter: http://twitter.com/wuodland
Have a look at my Photography page: http://bit.ly/N2aMTi
LinkBack URL
About LinkBacks
