Old 08-10-2005, 12:11 PM   #1 (permalink)
Jai Suresh
lywyre's Avatar
Default Err in Nokia 6600 BlueTooth Conn.
When I try to turn on the Bluetooth option in my Nokia 6600, it gives no reponse or hangs.
And also the Phone is generally slow even with out a memory card. Is there any way to resolve the problems, particularly Bluetooth, because I want to transfer files to and from my PC, please.
lywyre is offline
Old 08-10-2005, 12:58 PM   #2 (permalink)
With reference to your first problem, I had this problem with my 6600 once but restarting it solved my problem.
Your phone must be slow because you must have filled the phone memory almost to its maximum capacity with messages, contacts, pictures, sounds etc. Free some momory and then try.
If the bluetooth problem does not resolve even with a restart then it might be a hardware issue/manufacturing defect and so the phone will have to be given to service centre for repair/replacement (if its under warranty). Try to get a replacement.
blue_earth is offline
Old 08-10-2005, 08:34 PM   #3 (permalink)
Jai Suresh
lywyre's Avatar
hope it is not a h/w problem. thanx anyway
lywyre is offline
Old 10-10-2005, 06:10 PM   #4 (permalink)
mariner's Avatar
transfer all ur images,tones,videos etc to ur mmc card.keep the phone memory free. use a file manager like fexplorer t oremove unwanted stuff.
mariner is offline
Old 11-10-2005, 01:14 AM   #5 (permalink)
dattebayo
anispace's Avatar
try formatting
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
