Old 28-09-2005, 02:52 PM   #1 (permalink)
Default The Right Cellphone for the job ...
Could sum1 plz recommend a cellphone that has the following features:
Doubles up as a modem
Bluetooth
Infrared
Video and Sound Recording
Camera
All this @ under Rs.8000
megacoolxs is offline
Old 29-09-2005, 11:35 AM   #2 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
~Ngage Gamin Deck~
[x] bluetooth
[x] modem
[-] ir
[-] vdo n snd
[-] cam
ngage till date is da cheapst smart fone.... >=8000/-
betr go with a 2 nd hand 6600, or shell out a few more bucks and have the lil gizmo with all da fetrs!
aku is offline
Old 29-09-2005, 10:45 PM   #3 (permalink)
moshel's Avatar
some ppl ask crazy questions
bluetooth and infrared under 8k.
no bluetooth phone under 8k. except for ngage qd that is. but no cam
moshel is offline
Old 30-09-2005, 03:36 PM   #4 (permalink)
Geforce's Avatar
For your budget you can buy Sony Ericsson T630
This costs around 7k and has all the features you have requested
A list of the Features:
General Network GSM 900 / GSM 1800 / GSM 1900
Announced 2003, 4Q
Status Available
Size Dimensions 102 x 43 x 17 mm
Weight 92 g
Display Type TFT, 65K colors
Size 128 x 160 pixels
- Wallpapers, screensavers
Ringtones Type Polyphonic (32 channels)
Customization Composer, download, order now
Vibration Yes
Memory Phonebook 8 fields, 510 items, Photo call
Call records 30 received, dialed and missed calls
Card slot No
- 2 MB shared memory
- 300 organizer entries
Features GPRS Yes
Data speed
Messaging SMS, EMS, MMS, Email, Instant Messaging
Clock Yes
Alarm Yes
Infrared port Yes
Games Embedded (AlienScum, HoneyCave2, Minigolf, Vrally2) + downloadable, order now
Colors Frosty Silver, Black
Camera CIF, 352 x 288 pixels
- Java
- Bluetooth
- WAP 2.0
- T9
- Calculator
- Image viewer
- Scheduler
- Voice memo
- USB port
Battery Standard battery, Li-Po 750 mAh
Stand-by Up to 315 h
Talk time Up to 14 h
But i won't recommed this because its camera is not good at all. Consider at least VGA camera.
If you can just increase your budget to 10k. Then you have more options.
- Sony Ericsson K700i @Rs 10.5k
- Nokia 6600 @Rs 10.5k
GO for Nokia 6600, with latest updates which has 64MB memory card.
IT will cost you around 10.5k but it is WORTH IT as you can install applications.
IF you are really stricken for cash then there is 1 more option:
- Sony Ericsson K500i with VGA cam but no bluetooth
costs around Rs 8.5K
Geforce is offline
Old 01-10-2005, 04:25 AM   #5 (permalink)
aku
Gonna make it BiG
aku's Avatar
DATZ IT GO WITH NOK 6600
aku is offline
