Micromax superphone A56,Help for methods increasing internal memory.
Results 1 to 6 of 6
Thread: Micromax superphone A56,Help for methods increasing internal memory.
  1. #1
    Hope is what i believe in V.VAIDYA's Avatar
    Mar 2011
    Home-India , Pune , Maharastra
    Unhappy Micromax superphone A56,Help for methods increasing internal memory.
    My friend Brought micromax superphone A 56 and 8 gb class 4 microsd.
    (On my suggesting for jumping to android on a budget of rs 6000 , he was going for a nokia but used my explorer and changed mind.)
    Internal memory is just 45mb,regretting buying it.
    Please help us increase internal memory in any way possible without voiding warranty.
    App2sd / link2sd etc need root but we dont know how to root and also they leave 2-5 mb in internal memory due to which about 15-20 apps are maximum and phone becomes very slow.
    There are some hacks for increasing internal memory to 1gb using the xda specified method by partitioning microsd but that does not work here.
    Need some good and easy instruction from android enthusiasts and developers, we would be very grateful please help increasing it or just give a reply please.
    Popular Gadget Deals
    [I]Samsung Syncmaster 2233 full hd , Intel E5300 2.4 ,Asus p5k-pl-am\in,2GB zion ram,500 seagate hdd ,apc backup 550, Radeon 6570 GPU[/I]
    Samsung corby-dead,Nokia 5233-dead,HTC Explorer - stolen,[B]Karbonn A21 - Satisfied[/B]
  2. #2
    Jul 2012
    Smile Re: Micromax superphone A56,Help for methods increasing internal memory.
    i also have the A56 ....... i also have the same problem
    i am going to try a new way of doing it next weekend as i am having my exams
    if you want , you can try this and give me the results -
    A quick tutorial to ROOT Micromax A50 Ninja - xda-developers
    this is for the A50, but if we can somehow make it work for the A56 it would be great !!!!!
    Best of luck !!!!
  3. #3
    Mar 2011
    Default Re: Micromax superphone A56,Help for methods increasing internal memory.
    Thanks for replying , good luck for efforts in android development.
    Also can i unroot it if something goes wrong and claim warranty.
    There are ways to backup rom after rooting but how to do it before rooting.
  4. #4
    Jul 2012
    Wink Re: Micromax superphone A56,Help for methods increasing internal memory.
  5. #5
    Active on Several Forums kartikoli's Avatar
    Mar 2011
    Lucknow
    are you sure as people are reporting that the phone have 150MB internal memory and with 50~60MB used by OS
  6. #6
    Mar 2011
    No, it was just about 100 mb on first (cant remember as i brought it for my friend) but decreased to 45 mb when used the apps like gmaps,mail,etc for some days.just a few apps installed nothing more.
    But it had same internal memory than my htc explorer,problem can be solved by rooting.
  1. how we can change memory card in micromax funbook
    By satti.narayana@gmail.com in forum Mobiles and Tablets
    Last Post: 10-06-2012, 09:28 PM
  2. Increasing shared graphics memory
    By ComputerUser in forum Graphic cards
    Last Post: 04-05-2007, 07:39 AM
  3. Increasing Graphics memory
    By bizzare_blue in forum Graphic cards
    Last Post: 01-04-2006, 04:07 PM
  4. SE k300i increasing the memory
    By akshar in forum Mobiles and Tablets
    Last Post: 09-01-2006, 06:42 PM
  5. increasing Virtual memory
    By aathif in forum QnA (read only)
    Last Post: 21-04-2005, 09:18 AM
