Results 1 to 7 of 7
29-06-2012, 02:57 PM #1Right Off the Assembly Line
- Join Date
- Jun 2012
- Posts
- 10
Micromax funbook Internet problem
i purchased micromax funbook 2 days back but i am not able to start internet on it.
I have BSNL wifi modem.
funbook detects wifi connection asks for password, i entered it.
it connects to the wifi succesfully
but i am not able to browse net on browser or create micromax account or download any apps.
the internet is just not working.
Plz can someone help?
29-06-2012, 03:54 PM #2
Re: Micromax funbook Internet problem
I Think The Fault Is In Your Modem....
29-06-2012, 04:37 PM #3Right Off the Assembly Line
- Join Date
- Jun 2012
- Posts
- 10
10-07-2012, 07:08 PM #4Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 1
i am having the same problem.....plzzzz tell any solutions.....
11-07-2012, 01:12 AM #5In The Zone
- Join Date
- Apr 2012
- Location
- Noida,India
- Posts
- 394
have you tried using it on another wifi ?
11-07-2012, 09:45 AM #6
Not sure, but check for the MAC filtering option on your Modem, If it is enabled then u will be able to connect to modem but not the internet...so try disabling it..
Founder: Atumaharaj.com
Current Rig: Intel i5-760 3.0 GHz | Gigabyte H55M-S2 | Transcend 4GB DDR3 1333MHz | Sapphire HD 6670 1 GB DDR5 | WD 500 GB | CoolerMaster Elite 431 - Transparent Side Window
Old Experiment Rig: Intel P4 1.6 Ghz | Intel 945 | Hynix 1.2 GB 1333 MHz | Nvidia 6200 256 MB | Samsung 40 GB
Other Stuff: Samsung Galaxy 5670 | Seagate 500 GB USB 2.0 | HP Mini
06-08-2012, 05:52 PM #7Right Off the Assembly Line
- Join Date
- Aug 2012
- Posts
- 1
01-09-2012, 06:29 PM
Micromax Funbook
By Tenida in forum Mobiles and TabletsReplies: 1853Last Post: 09-03-2013, 06:12 PM -
How to connect Tata Photon USB Donlge to Micromax Funbook to get Internet
By riazam2006 in forum Software Q&AReplies: 0Last Post: 30-06-2012, 02:34 AM -
Micromax Funbook
By testuser in forum Buying AdviceReplies: 2Last Post: 29-06-2012, 08:39 PM -
[SOLVED] Google play problem on Micromax Funbook
By Tenida in forum Mobiles and TabletsReplies: 40Last Post: 09-06-2012, 01:07 AM
LinkBack URL
About LinkBacks
