Problem rooting Galaxy Y
Results 1 to 14 of 14
Thread: Problem rooting Galaxy Y
  1. #1
    Wise Old Owl anupam_pb's Avatar
    Dec 2008
    Port Blair
    Default Problem rooting Galaxy Y
    When I try to root my Samsung Galaxy Y, by using "update from SD card" option present in Recovery Mode, an error appears stating that "Can't mount SD card". I have tried using a different SD too but still no solution. How can I get my phone rooted ??
    I'm a beginner in rooting & using custom ROMs.
    Also how about this ROM
    Can i install it without rooting with above method(or any other) ?
    Popular Gadget Deals
    Desktop (@ home) :1st gen i3, 4GB DDR3 RAM, 500GB HDD, HD5670 1GB GDDR5 ;
    Laptop : Lenovo Ideapad Y500(Intel Core i7 , 8GB DDR3 RAM, 1TB HDD, 2GB GDDR5 GT650M, 15.6"FullHD Display );
    Samsung Galaxy S II > Nexus 4
    Join Dropbox: https://db.tt/563dYplc
  2. #2
    Jan 2012
    Default Re: Problem rooting Galaxy Y
    First you need to root your devices.
    Then install a Recovery to install a custom rom.
    Guide here:
    [VIDEO] WHITE-CZ Tutorial's [ROOT,UNBRICK,FLASH,RECOVERY,BOOTLOADER] ***EASY*** - xda-developers
    -CyberSa
    Android Fan,Developer and Supporter.
  3. #3
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
    Quote Originally Posted by anupam_pb View Post
    this is exactly how you don't root. first read about rooting and flashing custom recovery, etc else you'll end up with a dead mobile.
  4. #4
    Dec 2008
    Port Blair
    Actually I was trying to root my phone according to this tutorial.
    I tried to root my SGY using Super One Click Root, but the process hangs at Step 7
    I don't know what to do now ......
  5. #5
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
    have you tried unlock root?
  6. #6
    Dec 2008
    Port Blair
    @Sam : Download link is not working in the link given by you for Unlock root & I'm finding it difficult to find another working link. Also no working links for Z4root yet
  7. #7
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
  8. #8
    Dec 2008
    Port Blair
    I got a Z4root v1.3. I will try it soon.
    Unlock Root 2.3 is downloading very slowly, i hope that it downloads completely...
    I will post results soon...
  9. #9
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
    err Z4Root mayn't work on 2.3
  10. #10
    C.T.I.D AlphaQ's Avatar
    Jun 2011
    221B,Baker Street.
    u don't need to root ur phone to install this rom...
    -first download the rom and place it in ur sd card only in ur sd card not in any folder
    -den power off
    -den VOLUME UP+HOME+POWER together..
    -den Wipe data/factory reset
    -den wipe cache partition
    -install zip from sd card
    -select the rom and then the yes among the many no's
    remember that in recovery mode touchscreen wont work ... so use home button for selecting and power for back
    another thing to note is that u will be automatically rooted after installing this rom
  11. #11
    Dec 2008
    Port Blair
    I'm downloading the ROM, but you all must see this....
    Note:My SD card contains an "update.zip" file required for rooting stock ROM
    @Sam : Due to problems with my home's internet, Unlock Root's download is stopping at 99% (in fact about 80% of the files I try to download stops downloading at 99%)
  12. #12
    Jun 2011
    221B,Baker Street.
    well that error is not a problem..just download the rom and then flash it...
    ask ur friend to download if u hv problems while downloading...
  13. #13
    Dec 2008
    Port Blair
    Actually its a problem with most of BSNL home broadband connections. But no problem in browsing cafe(corruption). Once optic fibres are laid, problems will be solved...
    I downloaded this ROM
    OK, i rooted my phone with update package. Actually the problem was with memory card(8GB), which i got bundled with Nokia 5800. With my phone's bundled SD card, update was applied, now i will try custom ROMs.
    ROM manager says my phone is not supported(for CWM recovery ), what should i do to install it manually ??
  14. #14
    Jun 2011
    221B,Baker Street.
    download CWM separately...
    and as i said previously flashing this rom doesnt require cwm...stock recovery is fine...
    P.S:dont use this rom...amal das from xda makes many roms but they are quite buggy...only weui is decent...
    other good roms are creeds fusion and chobitsdigitals...
    another bit of advice:
    wait for a couple of months ..we may get a fully working cm port for our galaxy y...
  1. 07-03-2013, 01:32 PM
  1. Rooting Galaxy S2
    By ajayashish in forum Mobiles and Tablets
    Last Post: 26-06-2012, 12:11 PM
  2. X8 Rooting
    By Adibaba in forum Mobiles and Tablets
    Last Post: 16-04-2012, 08:36 AM
  3. Tutorial on Rooting Samsung Galaxy S !
    By augustya in forum Mobiles and Tablets
    Last Post: 16-11-2011, 11:54 PM
  4. What is rooting ?
    By bubusam13 in forum Mobiles and Tablets
    Last Post: 08-10-2011, 04:40 PM
  5. Replies: 7
    Last Post: 29-04-2011, 01:51 PM
