Issues with insufficient memory on LG Optimus Net
Results 1 to 21 of 21
Thread: Issues with insufficient memory on LG Optimus Net
  1. #1
    Wise Old Owl ajayritik's Avatar
    Aug 2007
    Hyderabad
    Default Issues with insufficient memory on LG Optimus Net
    Off late I get message often indicating that my phone memory is low especially if I try to install some new app. I tried as much as possible to move apps which can be movable to SD Card. Is there something I can do to free more memory that is the phone memory.
    Also I remember someone suggesting decrapify your android. Is this similar to rooting.
    Kindly help. Also currently have 2 GB Memory card. Is it ok if I upgrade to larger size. Heard stories saying phone goes slow if we increase the memory via SD Card.
    Popular Gadget Deals
  2. #2
    making future better Vyom's Avatar
    May 2009
    New Delhi
    Default Re: Issues with insufficient memory on LG Optimus Net
    Best way to gain memory on your Android device is by partitioning your memory card into an ext3/ext4 partition and then using Link2SD to links apps on them.
    But your device needs to be rooted for that.
    "Decrapify your Android" is the name of a thread, where various other methods of gaining memory is discussed. Search for it. Rooting is the term used to describe to root your device using some app.
    And, no, upgrading to bigger size memory card won't slow your phone down! That is one stupid urban legend!
    PS: I recommend you to search and read FAQ's about Rooting, Installing Custom ROM thread.
    My Nexus 7 and Guide to Rooting: http://www.thinkdigit.com/forum/mobiles-tablets/178938-nexus-7-thread-rooting-dual-booting-ubuntu-touch-10-steps.html
    My Boring Website: http://vineetkumar.me | My not so boring FB Geek Page: www.fb.com/geeksworld
  3. #3
    Aug 2007
    Hyderabad
    I read somewhere that if we do rooting and if it goes wrong the warranty will no longer exist.
    Is Custom ROM installation same as Rooting?
    Without doing rooting and installing Custom ROMS is there any way I can fix my memory problem?
    I hope to get more replies.
    Thanks Vyom.
  4. #4
    Human Spambot clmlbx's Avatar
    Aug 2006
    Indore
    @ vyom after reading your reply.. why do you need ext3/ext4 partition .. and you can use App2SD which can transfer apps without rooting..
    @ ajayritik
    AFAIK, as even I am searching how to do it and this is what I found out..
    1. First you have to root
    2. optional.. but very necessary IMO as safety precaution.. take backup of EFS data(IMEI) and all aother data like sms ,contacts..
    3. then install custom recovery
    4. optional... Take backup of your stock rom. from recovery..
    5. and then go for any Custom rom..
    yes with rooting you loose warranty but you can easily unroot it ... as I read and understood it..
    best thing you can do is root and delete all bloatware from phone to get more space..
    use apps like this
    Tap cleaner to delete caches and history
    advance task killer to free ram
    [TABLE="class: outer_border, width: 100%, align: center"]
    [TR][TD]Athlon II X4 635 @ 2.9Ghz[/TD][TD]Gigabyte GA-MA785GMT-US2H[/TD][TD]Kingston 2x2 Gb 1333Mhz DDR3[/TD][TD]WDC 500Gb Green[/TD][TD]Palit GTS 250 512mb[/TD][TD]Tagan 500W[/TD]
    [TD]Samsung B2030[/TD][TD]Lg DVD Writer[/TD][/TR][/TABLE]
  5. #5
    May 2009
    New Delhi
    Quote Originally Posted by clmlbx View Post
    We need to create an ext3/4 partition since then the phone treats that portion of memory as an extension to internal memory and hence phone can access it faster than normal SD card memory.
    Also, some widgets would have no problem moving to ext partition, which can otherwise break if moved to card.
  6. #6
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    I too need help for my Optimus Net Dual. Thing is no matter what I do or how much of Cache I clean or even if I uninstall applications hardly any phone memory is freed.
    Uninstalled 2 apps of 5mb and guess what? I only got 1.5mb of space. No they were not on the SD card partially, had them on phone memory. Help?
  7. #7
    May 2009
    New Delhi
    ^^ You can't really do much about it. Low internal memory will always be a big hindrance.
    Link2SD is the way to go.
    Also, you can try flashing custom ROM which are small in size, so that you are left with more internal memory.
  8. #8
    keen to learn..
    Mar 2010
    Amritsar
    somebody plz explain how to partitioned the SD card ext3/4.
    Samsung C3322 Duos
    Bajaj Discover 100T
  9. #9
    Sep 2010
    ^^from custom recovery menu. partition SD card to ext and then convert the ext to ext3/4. which recovery are you using?
  10. #10
    Aug 2007
    Hyderabad
    So guys you are all saying I can just partition the SD Card with ext3/4 and should work for some time. I don't need to do rooting.
  11. #11
    May 2009
    New Delhi
    Quote Originally Posted by ajayritik View Post
    You really haven't read the "FAQ's about Rooting/Custom ROM" thread, have you?
    To be able to format card, you need custom recovery to be flashed. And, to need to flash custom recovery, your handset should be rooted.
  12. #12
    Peak Oil is real! AndroidFan's Avatar
    Feb 2011
    1. You have to root. It is important...
    2. Backup your data on SD card. Its all going away...
    3. Partition SD Card to ext2, preferably 512 MB... (minimum 256 MB) with swap size 64 MB. Convert to EXT3...
    4. Restore backup. Then reboot phone...
    5. Install Link2SD from Google Play. Open it, select all apps, and "Create Link".
    6. Reboot your phone.
    7. Mission Accomplished...
    Daily Driver -- Galaxy Nexus Cyanogenmod 11 Nightlies
  13. #13
    Aug 2006
    Indore
    hey guys I have one question
    say if I have 16Gb card and I make 1GB EXT3 partition and my phone has just 320Mb..so will some data will store in my phone or it will completely shifted to card..
    Ext3 partition is to just let phone access it faster or it can even eradicate the need of more internal memory..
    as even you move apps to card some data is still in phone that affects phone memory..
  14. #14
    Aug 2007
    Hyderabad
    So there is no way I can get over this low phone memory memory unless I root the device?
    I will be able to free the phone memory only by rooting.
  15. #15
    May 2009
    New Delhi
    No. An ext partition can never eradicate the need of internal memory. Besides, there are many apps which are not recommended to move to ext partition also. Like launcher application. If you move it to the ext partition of the card, and lets say, your memory card gets kaput (or you just happen to remove the card), you won't be able to access any apps.
    So, an ext partition can increase your internal memory, but can never replace the actual internal memory.
    Yes.
  16. #16
    Aug 2007
    Hyderabad
    Quote Originally Posted by Vyom View Post
    Yes.
    Thik hai bhaiiya try karte hai. Tell me a good thread to know about rooting. Should I check the one created by sam?
  17. #17
    sam
    sam is offline
    Forum Moderator
    Jan 2010
    Guwahati
    hmmm rooting is as simple as connecting mobile to PC, turn USB debugging on from development menu and running UnlockRoot. done.
  18. #18
    Aug 2007
    Hyderabad
    Quote Originally Posted by Sam View Post
    Thanks Sam. Was about to PM you for help!
    Which mobile do you use currently?
  19. #19
    sam
    sam is offline
    Forum Moderator
    Jan 2010
    Guwahati
    same one Vyom is using. LG Optimus One.
  20. #20
    May 2009
    New Delhi
    No man!
    I am using the same phone which _you_ are using.
  21. #21
    Feb 2011
    No man!
    I am using the phone which you both are using...
  1. Can I expand my internal memory to 8GB for my LG Optimus Net
    By ajayritik in forum Mobiles and Tablets
    Last Post: 23-06-2012, 01:52 AM
  2. LG Optimus P500 Vs Motorola XT5 Xt502 with 2 GB Memory Card
    By navrajyadav in forum Mobiles and Tablets
    Last Post: 25-06-2011, 07:34 PM
  3. LG Optimus P500 Vs Motorola XT5 Xt502 with 2 GB Memory Card
    Last Post: 25-06-2011, 06:05 PM
  4. Insufficient Memory While Running Dos Program In Xp
    By anandh_kumardme in forum Software Q&A
    Last Post: 07-01-2009, 12:03 PM
  5. Inaccessible Due To Insufficient Permission
    By nithishr in forum Software Q&A
    Last Post: 07-12-2008, 03:27 PM
