Old 22-09-2005, 09:39 AM   #1 (permalink)
Default How to track a mobile phone.
can sum1 suggest how to track the da exact locations of mobile phones. if possible also giive any/some softwares to help & the process how to do it?
Mangal Pandey is offline
Old 22-09-2005, 12:29 PM   #2 (permalink)
Not possible unless you have access to the towers which you wont. It will be in the control of the service providers. There is a detailed article in this months CHIP on mobile phone and how one can be located by triangulation within 1 feet of where you are.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 22-09-2005, 01:28 PM   #3 (permalink)
MVP in VC++
Yes these things are handled by mobile operators through GPS(Global Postining System) and u can't do through any software or so.
cvvikram is offline
Old 23-09-2005, 03:33 PM   #4 (permalink)
chek these links out
http://www.findamobile.com/
http://www.verilocation.com/
http://www.childlocate.co.uk/
http://www.traceamobile.co.uk/
ishaan is offline
Old 23-09-2005, 03:51 PM   #5 (permalink)
The above sites only enable you to find mobile phones which you have registered. It cannot locate mobile phones in general. And all of them are a paid service.
AMD 64 3500+ Venice
icecoolz is offline
Old 24-09-2005, 08:41 PM   #6 (permalink)
yeah but still...tracking phones !
ishaan is offline
