Old 22-09-2005, 12:58 AM   #1 (permalink)
bizzare_blue's Avatar
Default Storing contacts in memory card
I have a Nokia 6600 and a Nokia 3230...Is it possible to store my contacts in the memory card instead of storing them in phone memory orSIM card? I tried Contacts manager but it just transfers a single file as a backup....and that's not wat I want....plz help...
Bitten by the open-source bug...
bizzare_blue is offline
Old 22-09-2005, 11:57 PM   #2 (permalink)
moshel's Avatar
goto tools -> memory
it will show u details of ur memory card. then click options and choose backup device memory on memory card.
to put the file on ur comp for saving, just put the card in card reader and join with comp then go into the card and there will be a hidden folder called backup, so copy that folder or the file inside it.
if u wanna restore then u have to do the same thing. just choose restore from memory card option.
this works on my ngage qd very well
moshel is offline
Old 23-09-2005, 12:40 AM   #3 (permalink)
Default Re: Storing contacts in memory card
Sorry moshel but I wrote that I do not want a single backup file...I want to use memory card to store my contacts instead of the phone memory(which is by default)....
