Results 1 to 20 of 20
Thread: Micromax Funbook problems
01-06-2012, 11:31 PM #1
Hello friends, I have bought the funbook today but unfortunately it is not recognised whenever I connect to my pc. It also hangs when I connect my airtel 3G datacard, please help me friends
Artificial Intelligence is no match for Natural Stupidity.
02-06-2012, 12:26 AM #2
Re: Micromax Funbook problems
i thought only tata usb dongle worked with the funbook as per the advertisement!!!
HP Pavilion dv6-6165tx | Intel Core i7-2670QM 2.2Ghz | AMD Radeon HD 6770M 2GB GDDR5 | 4 GB RAM 1333 Mhz | 750GB HDD| Apple Ipod 5th gen 32GB|HTC ONE X|Sony XB30EX Extra-Bass Stereo Headphone
02-06-2012, 12:35 AM #3
My Gizmos O_O
||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
02-06-2012, 12:54 PM #4
But how can I use my airtel 3G data card with the funbook, it just freezes when I connect it to my funbook.
02-06-2012, 09:31 PM #5Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 40
anand, I think you need to install custom ROM to use dongles other than tata.
the computer thing is easy, just install android drivers on your PC. the tutorial is there in first post of tenida's funbook thread.
05-06-2012, 09:13 AM #6Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 1
I have also bought a Micromax Funbook P300 a week back. I already own a BSNL 3g USB dongle 7.2 Mbps which I want to use with the Micromax tab. But it apears to be bundled with Tatadocomo usb dongle which when I tested it automatically got connected.
I am a retired person and also do not want to buy another dongle and want to make use of the existing BSNL dongle 7.2 Mbps. Can somebody guide me as to how to do it. I am also not a software geek and as such your systematic guidance will be of great help.
Addendum: I bought a Micromax Pocket Wireless Router at Rs.2500 appx (including credit card charges and VAT) and am now getting the mobile broadband wirelessly. But I would still like to use my USB dongle with the tablet directly.
I am sure, the members will appreciate my anxiety to use my already existing dongle instead of buying another one and adding to the plastic/electronic junk.
Thanx in advance.Last edited by ramadasan7; 23-07-2012 at 06:31 AM. Reason: I want to add additional information.
24-06-2012, 12:59 AM #7Right Off the Assembly Line
- Join Date
- Jun 2012
- Posts
- 1
Hi Friends,
I am facing a problem while playing videos on my funbook. when i try to forward a video, it does not happen. I am facing this problem only with large video clips, for example movies. But if i play a small clip, for ex. a song it works fine.
I downloaded MX Player as well but problem still persists.
Please advice if anyone knows solution to this problem.
Rgds,
Sachin
19-07-2012, 06:37 PM #8Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 1
Hi,
I have funbook, which just now stuck on white screen, after boot logo its goes in white display. Any solution please reply.
21-07-2012, 03:13 PM #9
Founder: Atumaharaj.com
Current Rig: Intel i5-760 3.0 GHz | Gigabyte H55M-S2 | Transcend 4GB DDR3 1333MHz | Sapphire HD 6670 1 GB DDR5 | WD 500 GB | CoolerMaster Elite 431 - Transparent Side Window
Old Experiment Rig: Intel P4 1.6 Ghz | Intel 945 | Hynix 1.2 GB 1333 MHz | Nvidia 6200 256 MB | Samsung 40 GB
Other Stuff: Samsung Galaxy 5670 | Seagate 500 GB USB 2.0 | HP Mini
21-07-2012, 03:42 PM #10Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 1
Hi ...i have recently purchased micromax funbook and have BSNL WIFI but there is a Wifi problem : whenever i try to connect my bsnl wifi with micromax funbook it shows my wireless router as by the name "DEFAULT" and shows connected...it does not ask for user name or password..browsers also shows internet is not connected...
but wifi works fine on my laptop...what to do?plz reply..
21-07-2012, 03:54 PM #11
Project Halcyon V2.1
2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
21-07-2012, 07:13 PM #12Banned
- Join Date
- Jul 2012
- Location
- Kanpur
- Posts
- 30
22-07-2012, 08:12 AM #13
Yeah..realized that now..
It seems that, MAC filtering is active as u say that u are able to access net via laptop and not fb.
Open ur modem / router's configuration page (type 192.168.1.1 in browser and admin as username and password)
Check if MAC access is enabled. If yes, disabling it might solve ur problem...Founder: Atumaharaj.com
22-07-2012, 03:33 PM #14
23-07-2012, 10:18 AM #15Right Off the Assembly Line
- Join Date
- Jul 2012
- Posts
- 1
steps
1. Go to Settings–> Slect More–> then Mobile Networks
2. Enable Mobile network and also enable data while roaming.
3. With the given Extension card for connecting? the USB port connect your Reliance.
4. Click on? the Mobile networks, in that you can see “TATA” with the dial number #777.
5. Click that, it will go inside that option,
6. Then Scroll to the user name and password section.
7. Select and enter your user name and password of your respective data card number (ie.? MDN Number)
8. Then save and start
28-07-2012, 01:06 PM #16Right Off the Assembly Line
- Join Date
- Jul 2012
- Location
- Guwahati
- Posts
- 49
Guys help me i took the Funbook from my friend and i was installing some apps from the google play store after some (15min) when i tried to make the screen on it did not so i used the reset option at last but after that only micromax thumb logo comes and stay that way. i kept it that way till the morning and the battery died. and when i plug in the charger it shows the same thumb logo
m very upset as it was of my friend so ny1 facing yhe problem plz help
28-07-2012, 06:36 PM #17Right Off the Assembly Line
- Join Date
- Aug 2010
- Location
- India
- Posts
- 45
Hey guys, I am facing a weird problem with my funbook.
Audio output is coming from both speakers and headphones. Tried factory reset using settings->backup n reset. But the problem still exists. pls help
18-08-2012, 08:38 PM #18Right Off the Assembly Line
- Join Date
- Aug 2012
- Posts
- 1
20-08-2012, 01:49 AM #19In The Zone
- Join Date
- Apr 2012
- Location
- Noida,India
- Posts
- 394
26-10-2012, 06:42 PM #20Right Off the Assembly Line
- Join Date
- Oct 2012
- Posts
- 1
Micromax Funbook
By Tenida in forum Mobiles and TabletsReplies: 1853Last Post: 09-03-2013, 06:12 PM -
Micromax FunBook Review
By Tenida in forum ReviewsReplies: 142Last Post: 14-08-2012, 06:54 AM -
Micromax Funbook
By testuser in forum Buying AdviceReplies: 2Last Post: 29-06-2012, 08:39 PM
LinkBack URL
About LinkBacks
