Old 20-09-2005, 12:13 PM   #1 (permalink)
Default polyphonic ringtones = wat pc format?
can some1 plz. tell wat format are the polyphonic ringtones that can be saved into mobile 4m pcs?
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 20-09-2005, 12:24 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Polyphonic ringtones r actually MIDI files with extensions either .midi or .mid.
U can d/l a lot of MIDI files from net and can transfer them from PC to ur mobile using various s/w available on net...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 20-09-2005, 05:09 PM   #3 (permalink)
thx Vishal for the info
also, wat r True Tones
Old 20-09-2005, 06:51 PM   #4 (permalink)
Microsoft MVP
True tone actually means: wav/amr/awb
*wav file r rather big, 1 min of default setting wav file can take up to 15mb of ur phone space
*amr only took up to 60kb of the same length of time
*awb only took to max 240kb of the same length of time
Difference between Polyphonic and True tones is that In True tones u can play real sounds, like ur own recording, animal sounds, etc. But in polyphonic its not possible...
Old 24-09-2005, 02:00 AM   #5 (permalink)
Hi vishal do you know any thing about creating a ringtone
Any Question can be answered
fact_speaks is offline
Old 24-09-2005, 01:24 PM   #6 (permalink)
Microsoft MVP
U can d/l MIDI files from net and can modify them ( resize or make supportable by phone ) using Nokia PC Suite available on Nokia site.
For true tones, u can d/l AMR files too from net and if u hv MP3 files then u can convert them in AMR using Nokia Multimedia Converter avilable on Nokia forum.
Old 24-09-2005, 01:32 PM   #7 (permalink)
hmmm thx for ur ringtone tips
