Results 1 to 30 of 34
Thread: Micromax funbook or iberry auxus
20-05-2012, 12:49 AM #1
Hi friends, I am planning to buy a new tablet on my birthday in June. I am little confused which to buy. My budget is around 10k. I have searched a lot and found out two models--micromax funbook(great in popularity BTW here in Delhi) & iberry auxus AX02. . I also have a Airtel 3G data card, also tell that does these two models supports this card. I am waiting for your response as soon as possible.
Artificial Intelligence is no match for Natural Stupidity.
20-05-2012, 09:05 AM #2
Re: Micromax funbook or iberry auxus
AFAIK, Funbook does not have a sim slot.
20-05-2012, 09:18 AM #3Alpha Geek
- Join Date
- May 2010
- Posts
- 838
Onda Vi10 from veedee is a good tab imo..more RAM and higher screen res is a huge plus point..though its priced slightly higher..
20-05-2012, 11:04 AM #4
Go for iberry auxus since u hv 10k budget. Its even ranked no1 in the budget tb list whereas funbuk is no2. U cn read the reviews 2 sort it out.
2 GB DDR2 , PENTIUM D 820 , GEFORCE 210 1GB,
Nobody is perfect. I am nobody
20-05-2012, 11:25 AM #5
I heard iberry is good but i don't think it have a usb port other than for usb modem!! And i read an ordinary pendrive is supported in funbook
i don't know if iberry supports it!! on the battery side iberry rocks
i would go for iberry
20-05-2012, 11:42 AM #6
What about this new tablet from VeeDee---Zenithink ZT-282 C71.......does anyone heard about this model, please tell me.
20-05-2012, 11:46 AM #7
Onda Vi10 is a better choice now.
Iberry Auxus doesnt have Bluetooth Support.HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
20-05-2012, 11:52 AM #8Right Off the Assembly Line
- Join Date
- Apr 2012
- Location
- in peoples minds!!!!!
- Posts
- 30
you can spend 3k more and buy the bb playbook...
20-05-2012, 04:06 PM #9
Remember this before suggesting onda vi10.
"It doesn't support Google Play"
20-05-2012, 04:23 PM #10
There are work-arounds.HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
21-05-2012, 11:30 AM #11
My primary use is net surfing & books reading. I play game occasionally. Micromax funbook is such a bang for money device i.e. it's hard to ignore it.
21-05-2012, 01:35 PM #12Right Off the Assembly Line
- Join Date
- Apr 2012
- Posts
- 17
21-05-2012, 10:58 PM #13Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 40
22-05-2012, 12:11 AM #14
22-05-2012, 01:44 AM #15Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 40
yes, but not in depth, I was a little busy since I got it. I will be checking it out fully this week. you can get many reviews in the main funbook thread. one suggestion, buy it locally even if it means a couple of hundred bucks extra, dont buy from online shopping stores other than flipkart.
first impressions, I am very impressed by it.
22-05-2012, 03:22 AM #16
I would suggest iBerry. Higher RAM, Better Battey, Better Touch Screen and good reviews. Also Micromax Funbook screen brightness is questionable.
22-05-2012, 08:39 AM #17
Installing Google Play on a tablet that doesnt support it is POSSIBLE.. However you will end up with something like Spice Mi-310.. Play will work but it will not display proper apps for your tablet to download.. My vote goes for funbook or Ainol Novo 7 Elf/Elf 2
22-05-2012, 12:53 PM #18
23-05-2012, 06:00 AM #19
You can check my detailed review also if you want.
Check my siggy for the review
Onda Vi10 is currently out of stock. And its not a hard task to install Play market. Rooting will solve the issue
Iberry Auxus is very good tablet but its screen brightness is not up to mark also the screen glass is very reflective. Very pity to work under light
Tablet with sim slot doesn't come cheap. You have to shell out more to get tablet with 3G facility.
It has limited app support but the hardware is way better than every cheap tablet out there
Can you explain more?My Gizmos O_O
||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
23-05-2012, 12:45 PM #20
Thanks to all of you specially @Tenida, I am buying the micromax funbook on 4th June i.e. on my birthday. I will give my experiance as soon as I get my funbook in my hand
23-05-2012, 06:31 PM #21In The Zone
- Join Date
- Mar 2004
- Location
- Chennai
- Posts
- 331
I'm also planning to buy funbook.. Saw this sale going on here .. Not sure if it's a good deal..
www.homeshop18.com
23-05-2012, 06:40 PM #22
23-05-2012, 10:37 PM #23Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 40
anand, I can't add much over what tenida said in his review. I am very satisfied with it.
don't believe people who say it has a problem with brightness, I use it in the lowest brightness level and it works fine. it's not just the product itself, you also have product support to think of. there micromax wins over pretty much any one else.
23-05-2012, 10:42 PM #24Alpha Geek
- Join Date
- May 2010
- Posts
- 838
25-05-2012, 11:48 AM #25
25-05-2012, 02:15 PM #26Banned
- Join Date
- Apr 2012
- Posts
- 100
iberry auxus is a good competitor i suppose.But it has a too glossy screen.
04-06-2012, 04:28 PM #27
Guys can anyone suggest a good, budget tablet with support for either bluetooth and/or GPS?
04-06-2012, 10:25 PM #28Alpha Geek
- Join Date
- May 2010
- Posts
- 838
I dont think any budget tab supports bluetooth or GPS..
apart from that, if you want you can get the Ainol Tornado for Rs6500
05-06-2012, 01:29 PM #29
05-06-2012, 04:11 PM #30Right Off the Assembly Line
- Join Date
- Jun 2012
- Posts
- 8
Funbook is better deal at that price.
micromax-funbook-tablet-reviewLast edited by samir_mankar; 25-06-2012 at 11:49 AM.
iBerry Auxus AX03G ► ICS, 2G/3G SIM SLOT, 4000mAh, 1GB ram @ Rs.9990
By kool in forum Mobiles and TabletsReplies: 59Last Post: 06-10-2012, 10:56 AM -
Ainol Novo 7 Elf II VS IBERRY AUXUS AX03G..
By ankit.kumar010203 in forum Mobiles and TabletsReplies: 57Last Post: 20-08-2012, 11:12 AM -
Micromax fun book Vs Iberry's Auxus 02 Vs Karbon smart tab
By kalyanrebba in forum Mobiles and TabletsReplies: 8Last Post: 14-08-2012, 08:40 PM -
IBERRY AUXUS AX03G LAUNCHED...!!!Question About Build Quality...!!!
By ankit.kumar010203 in forum Mobiles and TabletsReplies: 5Last Post: 03-07-2012, 06:58 PM -
Any More News About Iberry Auxus Ax03g?
By ankit.kumar010203 in forum Technology NewsReplies: 2Last Post: 29-06-2012, 03:44 PM
LinkBack URL
About LinkBacks
