Results 1 to 15 of 15
Thread: Normal GPRS on Blackberry Phone?
14-05-2012, 10:32 AM #1
Hello!
I recently brought a Blackberry phone and want to activate GPRS in it. I dont want to take the Blackberry Internet service. Rather I want to opt for the normal GPRS that is being provided by Vodafone at Rs.59 which allows me to access internet on my phone. Blackberry internet service costs me around Rs.399 which gives me BBM and internet. As I dont use BBM and I dont want to spend so much just for internet, I want to use the normal GPRS that I can use on any other phone other than Blackberry.
Problem is that one of my friend who is using a Blackberry phone said that we cannot use normal internet service on a BB phone. We have to opt for BB Internet service. Is that true coz I really find it hard to believe?
Helpline of Vodafone is not able to help me with such a small issue and so I thought you guys are my best bet...
So please help me.
Thank you.Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
14-05-2012, 10:49 AM #2
Re: Normal GPRS on Blackberry Phone?
you can use normal gprs but be wary of hellish costs.. a simple gprs plan will not work on a bb.. if you don't have a BIS you wont get anything from a bb.. a bb is pretty much useless without a bb plan.. i too used it on voda.. used the 1 week plan for rs 100..
I love TDF.. Everyone loves TDF.. Therefore, I am everyone.. :Problem? :D:
14-05-2012, 05:36 PM #3
Actually all I need internet is for Whatsapp and a little bit of surfing... I guess a normal GPRS plan will serve my purpose.
Win 7 Ultimate
14-05-2012, 06:35 PM #4
whatsapp wont work without a bis..
14-05-2012, 06:52 PM #5
Providers supply 2 plans
1 - BBM + Mail + Yahoo/Gtalk/Hotmail Chat, nothing more, nothing less, a webpage won't even open if you try to.
2 - BBM + Mail + Yahoo etc., + Surfing + Appstore Downloads
If you need Whatsapp, you need to buy plan 2, and its costlier compared to plan 1, if you are on postpaid, it can be a nightmare
BBM is activated by default if you buy any BB Plan, you cannot activate GPRS and skip BBM, as its a part of the pack, don't use it if you don't want it, simple as that.
And please, remove that number from your status.
15-05-2012, 09:40 AM #6
15-05-2012, 10:33 AM #7
i had a blackberry, an the stupid thing is that it only works perfectly with Blackbetrry internet service, somehow i managed to use it with GPRS by setting APN..
it was good device, but the service cmopany force you to buy the BIS which is costly, so i sold it, now moving to android,
15-05-2012, 10:59 AM #8
15-05-2012, 04:57 PM #9
Win 7 Ultimate
15-05-2012, 06:31 PM #10
15-05-2012, 08:04 PM #11
Heres the thing, if you want any app to run that uses internet you need to activate plan 2 mentioned in my previous post.
There is NO way around it, no matter how hard you try.
I hope its clear enough now?
16-05-2012, 07:52 PM #12
yes there is no hack for BIS throw the blackberry and get a good android phone
16-05-2012, 07:56 PM #13
05-10-2012, 02:38 PM #14Right Off the Assembly Line
- Join Date
- Oct 2012
- Posts
- 1
It is completely possible to use whatsapp on BB without BIS. all you need to is download a software called aerize wifix in your BB. just google it.
After installing wifix follow below steps.
go to Blackberry > Options > Aerize WiFiX.
Then in WiFiX, set "Enforce" to "Enabled" and click "New" button to add a new rule. A new window will popup. Set the "Name:" to "WhatsApp" or any name you like, then click "Add Host" button and add all of these URLs one by one (without http:// prefix):
sro.whatsapp.net
bin-short.whatsapp.net
xmppreg.whatsapp.net
xmpp-short.whatsapp.net
r.whatsapp.net
s.whatsapp.net
c103.whatsapp.net
c104.whatsapp.net
im101.whatsapp.net
im310.whatsapp.net
im402.whatsapp.net
im403.whatsapp.net
im404.whatsapp.net
mms1.whatsapp.net
$www.whatsapp.net$ (dont include $ while adding this module)
mail.whatsapp.com
root.whatsapp.com
$www.whatsapp.com$ (dont include $ while adding this module)
After you have done all the steps described above, go to Blackberry > Options > Aerize WiFiX. Point the cursor to WhatsApp then press BB (button on left of your trackpad) and select Edit Entry. Go to the last line of the entry where you can see "Request format:" as follows
http://<HOST><PORT><URI>;deviceside=true;interface=wifi
then change it to
http://<HOST><PORT><URI>;deviceside=true;ConnectionSetup= delayed;ConnectionUID=WAP2 trans
Finally click OK button to save the entry.
Exit WhatsApp, Pull Battery and Restart Phone.
After you have carefully finished all the steps above, try to start your WhatsApp application and it will start initializing:
you might have to try this no. of times but this trick works definitely. It has worked for me.
Good Luck.
AD
07-10-2012, 07:52 AM #15
only the new Blackberry os like the BBos7 can make use of normal gprs or edge function! And ill highly recommend u to visit a local vodafone store to help u with it!
Can I use 2G GPRS plans on Blackberry curve?
By shailesh in forum Mobiles and TabletsReplies: 1Last Post: 11-12-2011, 05:30 PM -
Blackberry curve 8320 gprs doubt
By win32.tr0jan in forum Mobiles and TabletsReplies: 3Last Post: 21-09-2011, 04:08 PM -
Blackberry phone
By utkarsh007 in forum Mobiles and TabletsReplies: 4Last Post: 14-04-2011, 06:05 PM -
Workaround to use BSNL/MTNL 3G at the cost of Normal GPRS
By Anubis in forum Broadband and DTHReplies: 5Last Post: 10-04-2010, 12:16 PM -
Please suggest a phone !! No, not a mobile phone. Normal Corded Phone
By din in forum Chit-ChatReplies: 7Last Post: 11-09-2008, 12:09 PM
LinkBack URL
About LinkBacks
