Results 1 to 30 of 42
Thread: Need help rooting symbian :\
08-05-2012, 01:49 PM #1
Hey guys! I've decided to root my Nokia 5233 (Symbian S60 5th Edition) phone... But I'm totally noobs at rooting and this is gonna be my very first attempt to rooting a phone...
I'd like to know the easiest and safest ways to go about this... (Like one-click apps)
And the reason for me trying to root my phone is just to customize it to my usage like getting Brightness Control (which actually sits in Menu/Settings/Phone/Display), Phone Lock Button (accessible from power button) and Sensor Settings (Menu/Settings/Phone) to my home screen... (I really don't know if it's possible to get these things done...
). I also want to experience the pros of a rooted device...
If it's really possible to get all these settings on the home screen please tell me an app (if any exists...) that can help me with this...
Thnx in advance !!
08-05-2012, 02:20 PM #2
Re: Need help rooting symbian :\
Can Symbian be rooted? If it can be, I don't think there is any straightforward way to do this.
08-05-2012, 03:02 PM #3
Google it. 5233 is an old fone n m sure u will get
2 GB DDR2 , PENTIUM D 820 , GEFORCE 210 1GB,
Nobody is perfect. I am nobody
08-05-2012, 03:14 PM #4
google could have done the trick : "http://helloox2.com/"
\Steam : noasarcangel
Steelseries : Winning Is Everything.
08-05-2012, 04:50 PM #5
08-05-2012, 05:18 PM #6
08-05-2012, 05:53 PM #7Right Off the Assembly Line
- Join Date
- Jun 2005
- Posts
- 43
check out
Daily Mobile Forum - Index
you will get all the rooting tools, mods and cfw for your nokia thereAMD X2 240, GA-MA78GM-S2H, OCZ 2GB DDR2, HD4850 512MB, Seagate 500GB Barracuda 7200.12,Gigabyte Superb 460W, CM Elite 335, AL BXR1221, AOC 2236VW,
PSP 2004,Kindle 3g,Sansa Clip+ 8 GB,PL-30
08-05-2012, 05:57 PM #8Hope is what i believe in
- Join Date
- Mar 2011
- Location
- Home-Odisha,India , Now -Pune , Maharastra
- Posts
- 74
Symbian can't be rooted , if it does then there must be other term other than "rooting".
You can customise your phone by installing custom firmware , to get some advanced features.Samsung Syncmaster 2233 full hd , Intel E5300 2.4 ,Asus p5k-pl-am\in,2GB zion ram,500 seagate hdd ,apc backup 550, 9500 gt GPU
My stale,dead,abandoned blog-Cant post its too bad and i am ashamed, improving it.
Samsung corby-dead,Nokia 5233-dead,Now-HTC Explorer
08-05-2012, 06:46 PM #9
Its Custom Firmware that you need.
Use C6^Photon for your Nokia 5233.
Google it.HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
08-05-2012, 06:54 PM #10
08-05-2012, 07:08 PM #11
08-05-2012, 07:15 PM #12
Great !!
So i finally know that I need a CFW !! Thanks a lot guys !! But can I install a CFW without rooting ??
08-05-2012, 07:28 PM #13
I think used android before and Rooting only Exist in Android
in Symbian u only need to Flash ur Mobile phone with FW files
LOLzzzzz U need to read Blaze Ultimate article Over here
And i used it it's OFW and I Know the diff. between OFW and CFW
08-05-2012, 07:48 PM #14
I believe in what i do and not only what i read.
I have used it on my Nokia 5230 along with several other CFW like Revenge6,AOV,Photon,etc.I know the difference.
Head to the Page of any CFW and you will find similar Bragging.
I have even cooked my own CFW
lol
08-05-2012, 07:58 PM #15
08-05-2012, 10:03 PM #16
^^My friend all CFW in nutshell are based on original Firmware only.
How can you expect modders to fiddle with core OS files.
For eg C6^Photon is based on original firmware of nokia C6 and has been used to port OFW C6 to older Noki 52XX phones.
Basically each CFW or OFW has 4 major files as you must be knowing.ROFS2/ROFS3/CORE/UDA.
In most CFW like AOV the original OFW Core file is kept intact and ROFS2/ROFS3 files are cooked/modded with tools Like Nokia FW Cooker to modify their functionality.
While in Ported CFW like Photon the Original Core file is modded whereas ROFS2/ROFS3 may or mayn't be changed.
In both cases UDA file is kept blank or original UDA is used.HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
08-05-2012, 10:38 PM #17
08-05-2012, 10:38 PM #18
08-05-2012, 11:07 PM #19
08-05-2012, 11:17 PM #20
Yes.
Make sure that you download Original Frmware files of your phone's current fw version using Navifirm in case you brick your phone during Flashing,so that you can revive your Phone.
Post in Your Current FW Version.Dial *#0000#.
Here is the Flash Tools Bundle.
Download Latest Core Files From Here
Download ROFS2 And UDA from The link posted by pratyush.
ROFS 3 is not required.Last edited by Sujeet; 08-05-2012 at 11:40 PM.
09-05-2012, 10:20 AM #21
I typed in *#0000# then it said:
Software Version: V 51.1.002
Custom Version: 51.1.002.C01.01
Model: 5233
Type: RM-625
PS: Thanks a ton for the links guys !!
And I'm pretty sure that none of these files are gonna install themselves on my device... So, can someone guide me on what to do after downloading these files... :\
And thanks again !!
09-05-2012, 10:59 AM #22
^^^u need to cook the project file to rofs2 in photon c6-06 which may be complicated for u So better to try other CFW which provide Pre cooked rofs2 with uda(Maybe blank)
For tutorials
Nokia 5800|5530|523x|X6 - RM-356|504|625|588|559 - Blaze Ultimate [New Blaze!]
[GUIDE]Flashing Tutorial For Newbies (SIMPLIFIED)
09-05-2012, 11:04 AM #23
09-05-2012, 11:32 AM #24
09-05-2012, 03:37 PM #25
Hey are there any mods for s60v3 devices like N73 ME ?
09-05-2012, 05:15 PM #26
anything for a e63?
09-05-2012, 07:24 PM #27
Thnx for the links Pratyush !! But I couldn't find any download link on the page that you shared earlier (This One)... Can you help me with that ??...
09-05-2012, 07:44 PM #28
You have to Login!!To download..as per the rules..IMOHCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
09-05-2012, 07:48 PM #29
09-05-2012, 08:45 PM #30
DOWNLAOD both.
SINCE you will need both of 'em.
Quick Tip.
The Larger one is ROFS2.12MB+
The smaller is UDA.in kbs probably.HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
Need Help rooting my HTC Explorer
By ParaXite in forum Mobiles and TabletsReplies: 2Last Post: 26-10-2012, 11:12 PM -
Rooting Galaxy S2
By ajayashish in forum Mobiles and TabletsReplies: 28Last Post: 26-06-2012, 12:11 PM -
hp leserjet m4345 mfp not rooting
By spanda in forum Hardware Q&AReplies: 0Last Post: 24-04-2012, 08:38 AM -
X8 Rooting
By Adibaba in forum Mobiles and TabletsReplies: 5Last Post: 16-04-2012, 08:36 AM -
What is rooting ?
By bubusam13 in forum Mobiles and TabletsReplies: 20Last Post: 08-10-2011, 04:40 PM
LinkBack URL
About LinkBacks
