Old 17-09-2005, 07:27 PM   #1 (permalink)
Default How to remove Comm Warrior in NOKIA 6600 Urgent ?
Please tell me hoe to remove Comm Warrior from Nokia 6600.
Please suggest a good anti virus for it.
Can anyone give truetones on e-mail : principal97@rediffmail.com
ankur123 is offline
Old 17-09-2005, 07:57 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
i suggest u install fexplorer first.
select commwarrior application & close it by pressing d'C' button. u may have to press/hold the menu key.
then go to fexplorer and open it.
go to C: > system/apps.
-delete the folder named 'commwarrior'.
then go to > System/Recogs.
-delete commrec.mdl.
then go to > System/Updates.
-delete comwarrior.exe, commrec.mdl, commw.sis.
lastly go to E: > and repeat all above deletion steps.
close fexplorer
open manager and remove commwarrior.
if u want to avoid manual steps, download and install simworks
or f-secure anti-virus. they will do the removal job.
for all download links click http://www.thinkdigit.com/forum/viewtopic.php?t=28668
have fun !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-09-2005, 01:52 PM   #3 (permalink)
gdatuk's Avatar
ya right follow anand ji..
i did it for my friend's mobile as well
it cleared up....
just one thing...will any antivirus not do the job??
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 21-09-2005, 01:29 AM   #4 (permalink)
spykids_666
Posts: n/a
the antivirus does not remove the virus, just prevents it from entering, so if you install the anti virus after installing comm warrior virus,
no use..
thanks
Old 24-09-2005, 01:55 AM   #5 (permalink)
Fxexplore is the 1 and the best choice to remove the application.
Any Question can be answered
fact_speaks is offline
