Results 1 to 6 of 6
Thread: X8 Rooting
  1. #1
    Jan 2012
    Default X8 Rooting
    i hav a sony ericson X8 and it is very slow at times and hangs regularly. Would rooting it solve the problem? and how do i root it
  2. #2
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
  3. #3
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    Default Re: X8 Rooting
    Rooting is not the straightforward Way to Boost speed of your phone but for sure you can claim some serious phone memory alongwith cleaning up bloatwares that comes pre installed with phone which might help to improve performance.
    Consider Sam's Guide In this section for rooting your phone.
    Links provided by Techfreak just above.
    HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    Samsung Galaxy Tab 2 |7.0 P31000
  4. #4
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    [REF] ALL ROMS | ROOTING. this is for X8. read a few links in the thread.
  5. #5
    Don Draper is coming back vamsi_krishna's Avatar
    Sep 2007
    Tirupati, Andhra Pradesh
    The best I can recommend is, MiniCM7 2.1.9. by nAa. It is basically CM7 with with nAa's editing. It is the best Custom ROM out there for X8 ( or even for E10, U20i).
    http://www.thinkdigit.com/forum/signaturepics/sigpic29632_3.gif
  6. #6
    Alpha Geek Soumik's Avatar
    Dec 2010
    Newport, NJ
    I ould also suggest u to get the custom kernel by nAa. It has quite a number of advantages over the stock kernel.
    There are no FC s or slow ups in the mobile. The speed will be very good. (Though in new condition... sony's stock UI is also very snappy). what is doesnt improve a lot is its battery life(especially if you use internet all the time). If you are ok with the current battery back up... you would be happier with this one.
  1. Need Help rooting my HTC Explorer
    By ParaXite in forum Mobiles and Tablets
    Last Post: 26-10-2012, 11:12 PM
  2. Rooting Galaxy S2
    By ajayashish in forum Mobiles and Tablets
    Last Post: 26-06-2012, 12:11 PM
  3. Problem rooting Galaxy Y
    By anupam_pb in forum Mobiles and Tablets
    Last Post: 24-06-2012, 01:03 PM
  4. Need help rooting symbian :\
    By ud0103 in forum Mobiles and Tablets
    Last Post: 26-05-2012, 11:00 PM
  5. What is rooting ?
    By bubusam13 in forum Mobiles and Tablets
    Last Post: 08-10-2011, 04:40 PM
