Results 1 to 5 of 5
Thread: Nokia N8 Battery query
16-03-2012, 11:00 PM #1Right Off the Assembly Line
- Join Date
- Dec 2010
- Posts
- 49
Hello!
I plan to buy Nokia N8 handset very soon but some1 told me that N8's battery is not detachable.
Is that the case?
Also, does it still have hanging probs. still after Anna update?
Pls. reply soon..
17-03-2012, 12:45 AM #2Alpha Geek
- Join Date
- May 2010
- Posts
- 836
Re: Nokia N8 Battery query
hangs occasionally...not too irritating...
Yes you cant remove the battery..
17-03-2012, 03:09 AM #3
To be frank, after a Belle update that phone crash rarely. In fact i have an E7-00.
Yes, you are true. The battery is not accessible to end user or end customer.
But why not, some other phones like HTC Desire HD - 19k [Price drop recently.]
17-03-2012, 10:05 AM #4
Yes, the battery is non removable.
Removing the battery by yourself will void the warranty.
After Anna update hanging issue has reduced drastically. You can go ahead with N8 if you don't care about the OS.Last edited by himangshu; 17-03-2012 at 10:06 AM. Reason: Spell check.
ASUS P5K-VM|Intel C2D E7200 2.53 GHz|Kingston 3gb DDR2 800MHz|XFX GT240 1gb|WD 160gb, Seagate 500gb|CM 350W PSU|Zebronics Antibiotic|BenQ G2220HD|Moser Baer DVD-RW|Logitech MX518
17-03-2012, 05:03 PM #5Right Off the Assembly Line
- Join Date
- Dec 2010
- Posts
- 49
Thanks for the replies!
Actually, I need Total Recall software (automatic call recording) primarily and i have used dat on a regular basis on Symbina platform.. Dat's why going for Symbian. Dis is the only reason to choose Symbian.. Else I also want Android..
Any solution for my prob?
I mean Total Recall or any other working software (for the same purpose) is available in Android 2.3??
Battery problem on s2 as wel ICS Query
By rickson23 in forum Mobiles and TabletsReplies: 3Last Post: 29-04-2012, 06:55 PM -
Laptop battery related query..
By siddharth.saiyan343 in forum Laptops and NetbooksReplies: 7Last Post: 22-03-2012, 11:41 PM -
[SOLVED]Query regarding laptop Battery.
By utkarsh73 in forum Laptops and NetbooksReplies: 20Last Post: 30-01-2012, 04:31 PM -
Nokia 800 battery feedback
By GERMZ in forum Mobiles and TabletsReplies: 23Last Post: 22-01-2012, 02:15 PM -
Laptop Battery Query
By trublu in forum Hardware Q&AReplies: 5Last Post: 16-12-2007, 11:51 PM
LinkBack URL
About LinkBacks
