Old 11-09-2005, 07:28 PM   #1 (permalink)
Default Improving GPRS Speed + Using Nokia 6021 with iBook
Hey frends,
I just bought a Nokia 6021. BT and EDGE. It promises internet speed upto 176 kbps. I am using airtel mobile office. I manage to get a mere 3 KBps and I am not happy with it. I guess it should be at least 10 KBps for an EDGE phone. Well higher Nokia models promise much higer speeds but 3 KBps is too slow.
Are there any tweaks or softwares available to improve the speed?
I have an Apple iBook. How do I configure GPRS on iBook? There are no drivers for Mac on Nokia website.
i plan to install Zone alarm and Ad Aware SE on my Windows PC. Will it increase/decrease the net speed?
Monster_AMD is offline
Old 11-09-2005, 08:01 PM   #2 (permalink)
i get upto 6Kbps on my mobile with Airtel Moblie Office. Mines a Motorola e398 phone. just Gprs not EDGE.
srijit is offline
Old 11-09-2005, 08:30 PM   #3 (permalink)
Monster_AMD, It appears that your fone has Edge but the network is not supporting it.
Call AirTel Customercare .. ask them whether they have Edge
Bcoz it must be supported by the network provider.
mobilegeek is offline
Old 11-09-2005, 09:39 PM   #4 (permalink)
expertno.1's Avatar
well to use tweking software i tell u to use
tweakmaster which increased my airtel gprs speed from 2 KB/s to 5KB/s
i.e
www.tweakmaster.com
for the EDGE query your ntetwrok must support this
as far as here the airtel service is concerned they do not provide EDGE
well it will decrease ur net speed but only .4 to .3 KB/s will be decreased and not more
BUT Security is first after Speed
Even GPRS supports a max of 17.3 KB/s speed
but for this u need to get all the time slots
generally we are priovided with two time slots so we have only speeds of 4-5 KB/s
Hope this helps you
expertno.1 is offline
Old 16-09-2005, 12:51 AM   #5 (permalink)
Default Thanx
Tahnk u guyz
