Results 1 to 17 of 17
  1. #1
    Broken In Mainak23's Avatar
    Feb 2012
    Malda,West Bengal
    Post Suggest me an android phone within 25k-30k
    Hiiiiiii...Everyone..I am going to buy a new phone within 15-20 days or so with these features..
    1. At-least 512Mb RAM [ prefer 768mb or More ]
    2. Internet browsing speed should be moderate
    3. Dual-core 1/1.2 GHz or 1.2/1.4 GHz Scorpion Cpu with Decent Gpu
    Help me out ...Thanks..
  2. #2
    Human Spambot ithehappy's Avatar
    Sep 2010
    Uttarpara
    GS II. Because you said screen size around 4.2".
    Otherwise G-Note.
    i7 950 ♦ SABERTOOTH X58 ♦ GTX580 ♦ 8GB RAM ♦ TX650 ♦ CM 690II ♦
    A 5.5" Plastic Pahblet called Galaxy Note II
  3. #3
    Alpha Geek anupam_pb's Avatar
    Dec 2008
    Durgapur
    Default Re: Suggest me an android phone within 25k-30k
    Samsung Galaxy SII. It will come in your budget.
    Desktop (@ home) :1st gen i3, 4GB DDR3 RAM, 500GB HDD, HD5670 1GB GDDR5 ;
    Laptop : Lenovo Ideapad Y500 (Intel Core i7 3632QM, 8GB DDR3 RAM, 1TB HDD, 2GB GDDR5 GT650M, 15.6"FullHD Display ) (Check My review for Y500's problems & its solutions) ;
    Samsung Galaxy S II(Omega v23 4.1.2)
  4. #4
    Apr 2011
    If you can extend your budget a little then go for Galaxy Note.
    Else Galaxy SII is better.
  5. #5
    Feb 2012
    Malda,West Bengal
    I think Galaxy Note screen is too big ..5.3" is too big ..just in my opinion ,, what about Motorola RAZR XT910 or HTC Sensation ??
  6. #6
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    GSII or RazrXT
    PS: What about the upcoming Sony Xperia S(not arc S)?
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  7. #7
    Feb 2012
    Malda,West Bengal
    Quote Originally Posted by tkin View Post
    GSII or RazrXT
    I think the price of Sony Xperia S will be more than 35k or so ...
  8. #8
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Well Xperia S will not be coming to India atleast before a month and will be priced around 30-35k.
    I agree with you the Note is lil big but not that big that it can't get fit is your pocket.Its an amazing device and is worth every penny.I suggest you to have a look at it and use it for a while and then decide.
    I won't suggest you to buy S2 as it is pretty old and common now.And hopefully its price will decrease in sometime...
    And have a look at HTC Sensation XE also its a very good phone.
    I haven't used RZR so won't comment on that.
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  9. #9
    Feb 2012
    Malda,West Bengal
    Quote Originally Posted by aroraanant View Post
    And have a look at also its a very good phone.
    Thanks for ur reply ...i will take a look at Samsung note..can you give some opinion about HTC Sensation XE ? is it better than S2?
  10. #10
    Lagger ~ .. pinku1993's Avatar
    Aug 2008
    NGP
    I would suggest you to go for Sensation XE. As per my experience, Sensation XE beats Galaxy S 2. Plus the bundled beats audio are just fab. The phone will cost you around 30k. I would suggest you to look for XE in the local stores. Online... you will have to pay 1.5k more (Letsbuy price: 31.5K)
  11. #11
    Feb 2012
    Malda,West Bengal
    Thanks for the replies...will take a look at Samsung note ..Can any1 tell me about HTC Sensation XE?
  12. #12
    Sep 2010
    Uttarpara
    Quote Originally Posted by Mainak23 View Post
    Sh!t, forgot about Droid RAZR, its great. But keep in kind it has locked bootloader, otherwise a great phone.
    Will you really bear a LCD screen in Xperia S? And no way it will be 35k, max 31-32k.
    So in short, either GS II or Razr. Or Note if you bear its size.
    Forget others I'll say.......
  13. #13
    Aug 2008
    Hyderabad, India
    Xperia S is one sexy phone, the camera is next to none(well maybe nokia N8).
  14. #14
    Feb 2012
    Malda,West Bengal
    If i can get Xperia S within 31k or so then i wanna go for that ..cause the specs n look are awesome..i can wait a month or so for that...otherwise Droid RAZR or Samsung note...Galaxy s2 good bt its bit common n bit old i think in my opinion..
    what about galaxy nexus?..how much it costs ? and is there any new nexus coming?
  15. #15
    Dec 2008
    Durgapur
    Galaxy Nexus Prime has been launched but not yet in India. I don't know what is Samsung doing ?!!
  16. #16
    Human Spambot abhidev's Avatar
    Sep 2009
    Nexus's screen is much brighter than Xperia S
    Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
  17. #17
    Sony Loverboy randomuser111's Avatar
    Jul 2011
    Quote Originally Posted by abhidev View Post
    abhidev,
    I don't understand why you had to resurrect this ancient thread ?
    And second FYI Galaxy Nexus screen is way dimmer than Xperia S's super bright display. And you stated the complete opposite.
    Anyway mods lock this thread so nobody else raises it back from the dead.
  1. Suggest Android Phone for 22k
    By prophet in forum Buying Advice
    Last Post: 27-06-2012, 02:34 AM
  2. Suggest me an android phone within 22k-23k
    By Skyrim in forum Buying Advice
    Last Post: 11-06-2012, 05:20 PM
  3. Suggest Android Phone Under 8k *strict*
    By echo9 in forum Buying Advice
    Last Post: 07-04-2012, 11:55 PM
  4. suggest android phone around rs 8000
    By sheelgupta31 in forum Buying Advice
    Last Post: 23-02-2012, 05:52 PM
  5. android phone. 40k . suggest??
    By paul.rohit in forum Buying Advice
    Last Post: 01-02-2012, 07:10 PM
