Results 1 to 25 of 25
  1. #1
    Jun 2011
    Post How is Sony ericsson-Live With Walkman????
    I'm thinking of buying it.How is it???
    Are there any technical issues with it.
    Or its best in its segment???
  2. #2
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Re: How is Sony ericsson-Live With Walkman????
    only other option is Motorola Defy from flipkart at around 13.3k. else go with Live with Walkman. Till now haven't heard of any issue with this mobile here.
  3. #3
    Neo
    Neo is offline
    Bird of Hermes Neo's Avatar
    Jun 2011
    Near my Computer.
    Quote Originally Posted by himanshu1114 View Post
    What did I tell ya ??
    Twitter | Steam | MyAnimeList
    Intel Pentium E5400 @2.7 Ghz | Intel DG41RQ | 2 GB A-Data DDR2 | WD Caviar Green 1TB | nVidia Geforce 8400GS 512 MB
    LG Optimus One P500 | Windows 8 x86 | Arch Linux x86_64
  4. #4
    Jun 2011
    Smile Re: How is Sony ericsson-Live With Walkman????
    Quote Originally Posted by royal.tarun View Post
    Okk Bt Motorola defy is out of my budget..
    Live With Walkman is the only option then.
  5. #5
    sam
    sam is offline
    Jan 2010
    Guwahati
    Defy is out of stock everywhere. was available at flipkart till yesterday but now out of stock.
  6. #6
    Jun 2011
    Is ebay claims the warranty if I buy live with walkman from ebay??
  7. #7
    Neo
    Neo is offline
    Jun 2011
    Near my Computer.
    ^^ Depends on the seller. If he/she provides warranty, then it would be mentioned somewhere on the page.
  8. #8
    Jun 2011
    that I also know dude but after mentioning also seller fails to do so then do ebay help in any case.
  9. #9
    sam
    sam is offline
    Jan 2010
    Guwahati
    if mobile have manufacturer's warranty, buy else skip.
  10. #10
    122.26.11.85 Zangetsu's Avatar
    Jan 2008
    Soul Society
    Sony Ericsson Live with Walkman is good budget android (1Ghz) phone under 15k...
    also the review is good in gsmarena...though it doesn't have Bravia Display technology
    HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
  11. #11
    rickyponting
    Yes, I have use this product and am benefited a lot. After using various products i have come to the conclusion that all the products of Sony-erriccson are good at sound quality and battery back-up and here too is the case. I would definitely recommend you to buy this product as it is worth spending money.
  12. #12
    Alpha Geek Soumik's Avatar
    Dec 2010
    Newport, NJ
    This SE LWW is a decent device. Performance would be on par with SE Arc, and with sound quality enhancing features, its a nice deal for music lovers.
    My only qualms for this is the smaller screen size.. which, to me, hampers usability a bit. And well, its in general SE battery life. I have seen X8 and X10 users complain abt it. I have read abt some SE Neo ppl complain a bit. So, this being similar to X8 in display and battery with a more powerful chipset, i seriously doubt its gonna give any better battery back up. Though official ratings are high, i have serious doubts. I have used X8 and its seriously has horrid battery life with data usage on. Even with custom kernel (Alfs) and rom (iROM based on CM7), it give a life cycle of around 14-18 hours. Which is pretty low for a small screened device in my opinion.
  13. #13
    Feb 2012
    Yes go for it, Just now my neighbor ordered it via ebay. It costed 12k bucks
  14. #14
    Explorer aroraanant's Avatar
    Mar 2011
    Aligarh>>>Delhi
    Quote Originally Posted by ineedcoupon View Post
    But I think manufacturer warranty is not covered in that price!!
    HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
    Sony 5.2ch Component home Entertainment System HT-M5
  15. #15
    Neo
    Neo is offline
    Jun 2011
    Near my Computer.
    Quote Originally Posted by Soumik View Post
    normally all Android phones have a max of 20 hours of battery backup. But that depends on the user.
    I'm a really heavy user. Battery hardly lasts for 10 hours, but that's on an unstable ROM.
  16. #16
    Dec 2010
    Newport, NJ
    Yeah i varies from user to user.. thats y.. i am saying by my own exp.. similar activities lasts for around 30hours plus easily on Defy, but maxes out at 16-18hours on an X8. Have tried Desire too, and on same usage that lasted around 26-28hours max. Comparing these devices, all modded, X8's back up for a much smaller screen is really pathetic.
  17. #17
    Jan 2009
    India
    Did someone delete my reply? May I know why?
  18. #18
    sam
    sam is offline
    Jan 2010
    Guwahati
    ^^ you are checking in the wrong thread. Smartphone in the budget of 12-14K. or go to control panel & check threads where you have posted.
  19. #19
    Jan 2009
    India
    Lol. What a shame! I always mess things up when I'm drunk. . Anyway thank you dude.
  20. #20
    Neo
    Neo is offline
    Jun 2011
    Near my Computer.
    SO, how is it? You Better share a review. k?
  21. #21
    Lagger ~ .. pinku1993's Avatar
    Aug 2008
    NGP
    A friend of mine grabbed the ericsson live from the local stores.. He paid around 14k for the phone. The phone is having bunch of features... Music is awesome.. The bundled headphones are decent. It wasn't better than my Skullcandy but it was good..
    The touch was also good but i felt that screen size is a bit small..
    Applications were working pretty well.. no problems in playing Angry Birds..
    Battery lasted for 1 and a half days.. We listened lodz of music around 50 songs.. snapped around 100 photos.. not much browsing (were looking for apps in the android market for few minutes.).. 1 call and 63 msgs ..
    Overall its a nice phone.. if u get it under 14k
  22. #22
    Jan 2009
    India
    Yeah, it's a bit tiny. I haven't seen it in flesh. What phone do you use? How do you compare the screen size to your phone?
  23. #23
    Apprentice Ravi.'s Avatar
    Feb 2012
    Now its available for 13k on letsbuy.
  24. #24
    Neo
    Neo is offline
    Jun 2011
    Near my Computer.
    He got it for 14K.
  25. #25
    THE HARDCORE GAMER mailshobhon's Avatar
    Oct 2011
    bangalore
    just recently bought Sony Live with walkman from Bangalore superb phone no performance issue best phone in its price bracket. don't get exited by the head its just a piece of junk try and get good ear phones to enjoy the music and i will tell the speakers in this phone is superb probably the best speakerphone i have ever heard in my life
    AMD Phenom II X6 1090T/Saphire HD 6870/XMS3 8gb ddr3 1600mhz ram/Cooler Master HAF 922/ AOC T2242WE MONITER TV/ Seagate Baracuda 2TB HDD/ APC 1000va/Cooler MASTER GX 750/Cooler MASTER Hyper N520/ LOGITECH Z2300 2.1 speakers, ASUS K53SV LAPTOP, 1TB SEAGATE GOFLEX HDD
  1. Sony Ericsson Live With Walkman - ICS update and other discussion
    By sling-shot in forum Mobiles and Tablets
    Last Post: 23-10-2012, 04:24 PM
  2. Replies: 10
    Last Post: 03-10-2008, 02:23 AM
  3. Sony Ericsson W550i Walkman Phone Review
    By devilhead_satish in forum Mobiles and Tablets
    Last Post: 14-04-2006, 12:03 PM
  4. nokia 6270 or n-90 or sony ericsson walkman range?????????
    By deepinder_mann1988 in forum Mobiles and Tablets
    Last Post: 18-03-2006, 05:11 PM
  5. Sony Ericsson W550i Walkman Review
    By hbk88in in forum Mobiles and Tablets
    Last Post: 30-12-2005, 05:53 PM
