Old 08-02-2012, 12:30 PM   #1 (permalink)
Jaskanwar Singh's Avatar
Default 5130xm internet access problem
I can access internet only through opera mini. When i download a game or app its downloaded to applications>games. But if that app requires internet, its unable to connect.
how to solve this.
I want to use jmIrc.
Jaskanwar Singh is offline   Reply With Quote
Old 08-02-2012, 03:09 PM   #2 (permalink)
@ndroholic
pramudit's Avatar
Default Re: 5130xm internet access problem
Its because you dont have complete setting... Tell me the operator and i'll tell you how to manually configure...
Intel Core 2 Quad Q8400 |Asus EAH4350 HD @ 720/480 (its summer time) | WD blue 500gb | Intel DG41RQ | 2gb DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
pramudit is online now   Reply With Quote
Old 08-02-2012, 03:10 PM   #3 (permalink)
Airtel
Old 08-02-2012, 03:30 PM   #4 (permalink)
@ndroholic
pramudit's Avatar
Go to configuration in settings...
Go to personal config...
Select add "web"...
After its created, select it and search for "use preffered access point" and set it to "no"...
Now the last option will be unlocked, open it, go to apn or acess point name...
Name it- airtelgprs.com
now save it..
At personal config, add access point and open it..
Change account name to whatever you want and change access point to airtelgprs.com
activate both in personal config...
Now go to configuration and check that both web(named personal config) and access point are selected as default and then select act default in all app...
You are done...
Is it working now...?
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
Old 08-02-2012, 04:18 PM   #5 (permalink)
thanks buddy. opera 5.1 and mail account works but jmIrc isnt.
it says ***connecting to irc.dal.net at port 6667.
But its stuck there only.
Old 08-02-2012, 04:34 PM   #6 (permalink)
Try connecting to: irc.freenode.net at 6667
Old 08-02-2012, 04:42 PM   #7 (permalink)
@ndroholic
pramudit's Avatar
I use jmirc a lot and it works for my aircel... Dont remember the port right now... You should try another port...
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
Old 08-02-2012, 07:12 PM   #8 (permalink)
ico's solution worked. Thanks both of you. Rep+
