Old 09-09-2005, 05:58 PM   #1 (permalink)
Good Boy
george101's Avatar
Default Mobile Cam
Hey guys i want to buy a mobile with ca and i want to know whether the video clarity is as good as th clarity of a digicam or handy cam when viewed on a pc. please give a reply
george101 is offline
Old 09-09-2005, 06:38 PM   #2 (permalink)
Most cellphones record at very low resolutions. I don't remember the exact figures but I think the resolution is somewhere around 176x144 at best. IT is nowhere compared with digicams or handycams. IF you view it on a PC, it will look worse.
Nemesis is offline
Old 12-09-2005, 04:40 PM   #3 (permalink)
you can try eti camcorder V2 with any symbian fone. It has option to shoot 320 x 240 video
kaysquare is offline
Old 12-09-2005, 07:37 PM   #4 (permalink)
gxsaurav
Posts: n/a
any video cam which support 640X480 image capture can support video capture at 320X240
can't say the same about frame rates,
better if u buy a digicam
Old 13-09-2005, 09:06 AM   #5 (permalink)
MVP in VC++
if u really want capture good video then better go for Digicam
cvvikram is offline
Old 14-09-2005, 02:49 AM   #6 (permalink)
You Should Take a Digi Cam .. bcoz mobile cams arent good for videos.
mobilegeek is offline
Old 14-09-2005, 12:03 PM   #7 (permalink)
Go for NOKIA - N90 which has QVGA format video recording
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
