Old 08-09-2005, 08:46 PM   #1 (permalink)
bizzare_blue's Avatar
Default Formatting a mobile
Is it possible to format a mobile (Nokia 6600) and instal its OS as it is done ona PC?
Bitten by the open-source bug...
bizzare_blue is offline
Old 08-09-2005, 08:58 PM   #2 (permalink)
Just Do It
Wrong Section posted, u shud be aware of it.
These should help. Try it.
http://www.theunlocker.co.uk/tutoria...nokia_6600.php
http://wiki.ehow.com/Format-Nokia-6600-Device
http://wiki.ehow.com/Discussion:Form...ia-6600-Device
Charley is offline
Old 08-09-2005, 09:13 PM   #3 (permalink)
expertno.1's Avatar
here one
http://archives.java.sun.com/cgi-bin...&F=&S=&P=27093
expertno.1 is offline
Old 08-09-2005, 11:40 PM   #4 (permalink)
The Hardware Labs
mohit's Avatar
To format your cell ( Symbian )
Tested on 6600 and 7610
Ur battery should be full for it
1) Switch ur phone off
2) Press "call"+"*"+"3" and then press the POWER ON button ( keep all of them pressed ).. till the time phone comes on and "FORMATING " word comes on screen..
VOILA!! all formatting and restoration of phone memory to original state..
(thanx to khandu for this info which he had posted on a thread related to nokia phone codes)
mohit is offline
Old 09-09-2005, 11:57 PM   #5 (permalink)
godsownman's Avatar
Is the operating system of the phone reloaded after the format process is completed automatically or do we have to do it manually . What are the requirements if we have to manually do it .
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 10-09-2005, 12:35 AM   #6 (permalink)
The Hardware Labs
mohit's Avatar
@godsownman
the operating system is reloaded automatically. u lose all ur data and the phones memory is restored. the phone becomes fresh n fast.
mohit is offline
Old 10-09-2005, 01:13 AM   #7 (permalink)
Just type in *#7370# it will ask u do u want to restore factory settings say "Yes" and then it u will have ur symbian OS reset=formatted
fighting for peace is like ****ing for virginity
cryptid is offline
Old 10-09-2005, 01:32 PM   #8 (permalink)
godsownman's Avatar
So how much time does this process take.
Thats really easy .
I never thought it could be so easy .
Old 10-09-2005, 06:21 PM   #9 (permalink)
vignesh's Avatar
Its not a very long process.
vignesh is offline
Old 10-09-2005, 11:35 PM   #10 (permalink)
well the process should take around 3 to 4 mins but it is slightly higher on a 6600 i have personally observed it
cryptid is offline
Old 12-09-2005, 12:59 AM   #11 (permalink)
dattebayo
anispace's Avatar
just make sure that the battery is full or connect ur phone to a charger while formatting.
Because if the battery gets empty while formatting u will end up with a brick.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 12-09-2005, 07:36 PM   #12 (permalink)
Distinguished Member
anandk's Avatar
a brick ! thats hilarious !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 16-09-2005, 08:17 PM   #13 (permalink)
godsownman's Avatar
Are there any tricks like this for an Ngage phone.
Will this also remove any viruses that may have entered the phone.?
I'm asking this on behalf of a friend .
Thanks
Old 16-09-2005, 11:24 PM   #14 (permalink)
How to format 3230???
Old 16-12-2005, 04:48 PM   #15 (permalink)
After formatting is it required to load operating softwares in 6600.
pandahk is offline
Old 16-12-2005, 07:27 PM   #16 (permalink)
I tried it....n man!! its as easy as it can get....I tried it on 3230 too....works fine...
Old 16-12-2005, 07:49 PM   #17 (permalink)
Commander in Chief
QwertyManiac's Avatar
After formatting ur PC, is it necessary to load the OS and stuff ?
SURE AS HECK YES !
QwertyManiac is offline
Old 13-02-2006, 04:17 PM   #18 (permalink)
Please tell me if taking backup of phone memory also backs up the the phone book? If no, the how can I backup the phonebook without a PC??
krish is offline
