Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 61 to 90 of 239
  1. #61
    Alpha Geek choudang's Avatar
    Sep 2005
    Guwahati
    Default Re: [FAQ] Rooting, Custom Recovery, Custom Rom and Android Glossary
    mini has 320 MB internal storage, and she is using 8 gb instead of default 2 GB.
    -- For every action, there is an equal and opposite criticism.
    Nikon D3100, 18-55mm, 35mm, Simpex 333
    Flicker: debaxish
    Blackberry 9100, Xperia Ray
  2. #62
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    but that doesn't help. by default Android will install apps to internal memory. and as all apps can't be moved. also even if an app can be moved, a small section is left in internal memory.
  3. #63
    Sep 2005
    Guwahati
    can we change that default setting?
    Flicker: debaxish
  4. #64
    Neo
    Neo is offline
    Bird of Hermes Neo's Avatar
    Jun 2011
    Near my Computer.
    ^^ Root is required for changing that setting. CyanogenMod has that setting inbuilt.
    Apps2sd is the best solution for that.
    Twitter | Steam | MyAnimeList
    Intel Pentium E5400 @2.7 Ghz | Intel DG41RQ | 2 GB A-Data DDR2 | WD Caviar Green 1TB | nVidia Geforce 8400GS 512 MB
    LG Optimus One P500 | Windows 8 x86 | Arch Linux x86_64
  5. #65
    The Chosen One sameer.pur's Avatar
    Jul 2005
    Jaipur, Bhilwara (Rajasthan)
    Talking Re: [FAQ] Rooting, Custom Recovery, Custom Rom and Android Glossary
    Quote Originally Posted by choudang View Post
    Yes you can, without root also..
    But be warned, that you are warned..
    • Requirements
      1. An Android Device (Obviously.. ) (Root not required)
      2. USB Cable
      3. A PC (Any OS will do Windows, Mac or Linux)
      4. Android SDK or replacement for ADB (Install android sdk from official site. Use drivers for your device)
    • Steps
      1. Run command prompt or terminal
      2. use command 'adb devices' (will show list of connected devices) (you should have android sdk's path/platform-tools in your classpath)
      3. use command 'adb shell' (will open a $ prompt)
      4. use command 'pm setInstallLocation 2' ( will set default install location to sd card ) (0 for auto, 1 for internal, 2 for sd card )
    Now whatever new apps you install will be installed to sd card. they will still take space on internal memory though for dalvik cache, app-cache, private-cache etc.
    Note-> If you want to revert back to original use option 0 in step 4.
    I am not in any way responsible if your phone transforms into a autobot or decepticon..
    Serious Note-> I have seen some weird behavior with this, apps which are set to install in sd card by default (i.e. games like angry bird), are installed in internal. You could just move them to external though. My advice would be to use this command to enable moving to sd card and then revert back.
  6. #66
    Neo
    Neo is offline
    Jun 2011
    Near my Computer.
    o.O thanks, btw. That sounds risky or is it? I think i used that before, a year or so.
  7. #67
    Jul 2005
    Quote Originally Posted by Neo View Post
    Actually I believe it's still safer than app2sd/data2sd scripts.
    You won't lose warranty for this.
  8. #68
    Jul 2010
    My SGS GT I9000 (rooted) has 2.3.3 firmware (baseband I9000ddjv5, Build Gingerbread ddjv9).
    Can I update with this NEW Value Pack XXJW4 2.3.6 (I9000XXJW4_I9000OXAJW4_XEU)? Will it work in India?
    x6 1055T, MSI890GXM_G65, WD CB 500GB, Corsair 1600 Mhz C9 2x2GB, BenQ E2200HD, Corsair 550VX, CM Elite430 , APC 600VA, CM Hyper 212+.
  9. #69
    Firecracker to the moon theserpent's Avatar
    Nov 2011
    Mangalore
    Suggest some good roms for galaxy MINI(Pop)
    A girl is someone who eyes an Iphone,wants a S3,Read's all good about Xperia and LG but at last ask's her Noob friend how is micromax and buys it
    Gadgets/Gaming RIG
    HD 7750||Nexus 10 :) || Canon Sx150 || Ipod touch 4g|| Sound magic es18
  10. #70
    Oct 2006
    I am new to Android, I bought LG 2x p990. Using from last 2 months.
    I am quit happy with my p990 except Battery Life.
    After using GO SMS Pro, I want to make default message app. and want to remove default message app.
    Can I uninstall some unwanted app like car home, email, google+, music etc
  11. #71
    Simply a DIGITian krishnandu.sarkar's Avatar
    Nov 2007
    Kolkata
    I'd suggest you not to remove the default messaging app. It may affect the functionality of the device. Though if you want to try it, I'd highly suggest you to take a backup of it using Titanium Backup and then remove it. So that in case of any fault you may restore it.
    You can remove apps like Car Home, Email, Google+, Music etc.
    use titanium backup for removing those. Ofcourse don't forget to take backup before removing any app.
    • Read The Forum RULES First.
    • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
    • Before Starting A New Thread Read The STICKY THREADS First
    • Before Participating In Bazaar Section Read The BAZAAR RULES
  12. #72
    sam
    sam is online now
    Jan 2010
    Guwahati
    ah, don't remove email. if you ever need to set email again (read hard reset) then you'll be in big trouble. though removing any specific email client like GMail or YahooMail should be safe. Don't simply kick out apps. Google a bit first.
  13. #73
    Nov 2007
    Kolkata
    ^^Thanks for the Correction.
  14. #74
    Oct 2006
    Thanks to all, Is rooting necessary to remove default app ?
    Because, I am not getting uninstall option for this app.
  15. #75
    making future better Vyom's Avatar
    May 2009
    New Delhi
    Quote Originally Posted by gcbeldar View Post
    By default app, I think you mean stock app.
    Yes rooting is necessary to remove stock apps. And if after rooting also you don't get uninstall option then you will have to try titanium backup to remove it.
  16. #76
    Oct 2006
    Quote Originally Posted by Vyom View Post
    Sir, After rooting can remove default "Contact, Dialer & Message App" and replace with Go Contact, Go Dialer and Go Message ?
  17. #77
    May 2009
    New Delhi
    You can still use Go Contact, Go Dialer and Go Message without removing the stock apps.
    Removing those stock apps is not recommended, since it can cause instability to the OS.
  18. #78
    Oct 2006
    With Go Luncher Ex I am able to make "Go Contact/Message" as default. But my P990 starts lagging by 50%
  19. #79
    Jun 2012
    Bhopal
    Question Re: [FAQ] Rooting, Custom Recovery, Custom Rom and Android Glossary
    hey bro,
    i m new to android phns just 1.5 yrs......I have read all the forums about rooting!!
    I have a Lg Optimus me P350 & i want to root my phone!
    I have used the apps z4root, gingerbreak, superoneclick but it did'nt work.In gingerbreak & z4root it just goes on but nthin happens and also no bysybox or superuser is installed .
    Pls help me with this.
    Thnx.
  20. #80
    Oct 2006
    How to root My Friends HTC Wildfire running 2.2.1?
  21. #81
    Jan 2012
    You can root it via Unrevoked.
    unrevoked
  22. #82
    Rookie Mr. Officer's Avatar
    Dec 2011
    Delhi, NCR
    LG Optimus P500
    Android OS 2.2.2
    Kernel Version 2.6.32.9 [Mar 29 2011]
    Build No. FRG83
    Software version V10e-MAR-28-2011
    I have rooted the phone with Gingerbreak.
    I've also followed the instructions listed here
    Can I now install ROM's like these Dynamite or G-T-R V7.8 ?
    PS: I already have the zip file for Dynamite ROM
    Since I already had the above mentioned files so decided of giving the Dynamite ROM a try and followed these steps below:
    4. INSTALLING CUSTOM ROMs
    BEFORE FLASHING ANY ROM, DO A NANDROID BACKUP FROM CUSTOM RECOVERY
    Since all the ROMs have their own kinds of partitions to be created and other requirements, you can check them at the ROM specific pages.
    General procedure to follow for installing a Custom ROM
    Boot into Custom Recovery
    Wipe your cache, dalvik cache, SD card
    Make partitions according to the ROM requirement
    Wipe cache again.
    Connect Phone to PC
    Toggle USB MS and paste the ROM zip file to a folder called AAA in the root of the SD card
    Disable USB MS.
    Detach phone from PC.
    Select 'Flash from zip' option in Custom Recovery menu
    Select the ROM file
    Flash the ROM file
    After flashing is finished, Reboot the phone.
    Note: It will take some time to flash and reboot into your new Custom ROM. The phone may stay with the boot logo displayed for a number of minutes. Do not switch off phone during this period.
    Once the flashing starts I get this error immediately
    E:Wrong digest:system/app/Mms.apk
    E:Verification failed
    Installation aborted
    Any help is highly appreciated.
    E5300 @ 3.60 GHz 8-) ♦ GA G41MT-S2 ♦ 4GB 1333XMS3 ♦ CX 500V2 ♦ MSI R6670-MD1GD5 ♦ CM HYPER TX3 ♦ 250GB HDD ♦ MK 320 ♦ Razer DEATHADDER BE ♦ Goliathus Control - "L" ♦ XBOX360 Controller ♦ JVC HARX-900 ♦ LG L192WS ♦ SOLO 600VA
  23. #83
    Nov 2007
    Kolkata
    Probably corrupted .zip. Download the ROM again and try to flash it. If it still produces the same error, report it on XDA at respective Development Thread.
  24. #84
    Dec 2011
    Delhi, NCR
    I'll download ROM.zip again but any where else you think I would've goofed up ?
  25. #85
    May 2009
    New Delhi
    Quote Originally Posted by Mr. Officer View Post
    Have you flashed the custom recovery Amon.Ra properly. Are you able to go into the recovery (which probably would have an interface with green colour)?
    Also, the error you mentioned (Wrong digest:system/app/Mms.apk) clearly states it has something to do with the .apk file. So, a corrupt apk is probably the only safe assumption.
    Try another ROM. There is no shortage of choices if you are on the new baseband. Even on old baseband there are lot of good choices.
    Good luck.
    PS: There's a special thread for LG P500. Just FYI!
  26. #86
    sam
    sam is online now
    Jan 2010
    Guwahati
    turn signature verification off and try again. or AmonRa recovery is old build or lastly corrupte download. you can check if corrupted zip by manually extracting the .apk file. BTW why don't you try Oxygen rom?
  27. #87
    Dec 2011
    Delhi, NCR
    ^^thanks for your replies
    This's what I did:
    a) Rooted phone with gingerbreak [success]
    b) installed "terminal emulator" from android market [success]
    c) d/l amonra recovery and extract files in SD card root folder [success]
    d) open terminal emulator - type SU (enter) and then SH (enter) and then sh /sdcard/rf.sh -- this takes me to recovery [success]
    Once in recovery :
    I took complete NAND backup.
    Wipe cache/dalvik-cache/sd card
    Make partition sd-ext
    wipe cache again
    connect phone to PC
    Enable USB-MS toggle
    Create a folder AAA in SD card root and paste ROM.zip in it.
    Disable USB-MS toggle
    Disconnect phone from PC
    select flash from zip → SD card → AAA → ROM.zip
    Start flashing - after few seconds
    currently my phone's - Kernel Version 2.6.32.9 is this compatible with the ROM I've been trying to flash ? I feel the ROM in question is based on [KERNEL] 2.6.35.13
  28. #88
    sam
    sam is online now
    Jan 2010
    Guwahati
    ^^ rom is corrupted for sure. it doesn't matter what is in your mobile. Android 1.0 or 4.0. 2.6.32 or 2.6.35 kernel. you can flash a new rom.
  29. #89
    Dec 2011
    Delhi, NCR
    Quote Originally Posted by Sam View Post
    Office colleagues are of the same opinion as well !!
  30. #90
    sam
    sam is online now
    Jan 2010
    Guwahati
    why not upgrade the mobile to 2.3 by visiting a service center then try rom for new baseband. you get better battery life also.
  1. 09-05-2013, 12:49 PM
  2. 18-04-2013, 03:12 AM
  3. 09-04-2013, 02:53 PM
  4. 06-04-2013, 12:25 PM
  5. 01-04-2013, 03:12 AM
  6. 27-03-2013, 04:06 PM
  7. 08-03-2013, 03:47 AM
  8. 05-03-2013, 04:51 PM
  9. 27-02-2013, 01:08 AM
  10. 23-02-2013, 10:42 AM
  11. 20-02-2013, 11:51 AM
  12. 17-02-2013, 05:36 PM
  13. 24-12-2012, 12:52 PM
  14. 15-12-2012, 09:24 PM
  15. 01-11-2012, 06:07 PM
  16. 04-07-2012, 06:34 PM
  17. 02-07-2012, 11:00 PM
  18. 26-06-2012, 01:29 PM
  19. 17-06-2012, 02:25 AM
  20. 17-06-2012, 12:25 AM
  21. 16-06-2012, 07:49 AM
  22. 15-06-2012, 06:46 PM
  23. 15-06-2012, 06:41 PM
  24. 15-06-2012, 06:21 PM
  25. 15-06-2012, 06:01 AM
  26. 14-06-2012, 08:26 AM
  27. 13-06-2012, 08:41 AM
  28. 12-06-2012, 07:12 AM
  29. 09-06-2012, 11:55 PM
  30. 06-06-2012, 01:10 PM
  31. 03-06-2012, 07:33 PM
  32. 02-06-2012, 05:33 AM
  33. 31-05-2012, 02:28 PM
  34. 28-05-2012, 03:30 PM
  35. 28-05-2012, 03:15 PM
  36. 28-05-2012, 01:48 AM
  37. 24-05-2012, 07:21 AM
  38. 23-05-2012, 11:06 PM
  39. 03-03-2012, 07:41 PM
  1. Questions about Rooting & Installing Custom Roms
    By Skyrim in forum Mobiles and Tablets
    Last Post: 15-06-2012, 08:26 PM
  2. Replies: 9
    Last Post: 07-05-2012, 02:33 PM
  3. What to know to do Android rooting and custom ROMs
    By kiranm516 in forum Mobiles and Tablets
    Last Post: 24-01-2012, 11:56 AM
  4. Noobs Guide to rooting and installing custom rom
    By sam in forum Mobiles and Tablets
    Last Post: 14-01-2012, 12:55 AM
