Old 06-09-2005, 08:43 PM   #1 (permalink)
Default Samsung C 210 or LG G 1600 Which is a better option?
Hello all,
I'm new to this forum. Just gone thru the threads and found it really cool and informative.
I plan to buy a new mobile which has GPRS, WAP, MMS and less than 5K. I found 2 options ie; LG G1600 and Samsung C210. These two has 95% same features like GPRS etc.
Please help me to make a right decision. U guys here may have used thse 2 mobiles. So pls compare
Another qn is I will be able to get internet in these phones by taking the EDGE from Airtel post paid? Can I connect these models to PC? These phones have GPRS class 10.
Thanks.
Design Geek
simplysaj is offline
Old 06-09-2005, 09:12 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
I would prefer LG1800, as it got many cool features that even a mid level phone dot have. It got a MP3 player with 61mb internal memory, 256k color LCD, voice recording which is missing in C230.
You get BT headsets and stereo headsets free with LG phones. So you get stereo headsets with this piece.
Of source, C230 got FM with loud speakers and got a good speaker system. And a FM radio costs only rs.40 in a market
1600 is cheaper also.
1600--> 4,250 rs.
C230 --> 5,100 rs.
Abt the EDGe, no you cant use the same with this phone.
And you can connect LG 1800 to the computer as it has USB connectivity options. I am not sure abt Samsung C230 (but I feel, we cant connect to computer, that GPRS can be used on your Mobile only to view WAP sites as they had with C100/C115).
Edit:
Got confused with 1600 and 1800. By the way, go for 1800 as it's chaper than C230 anyway.
drgrudge is offline
Old 06-09-2005, 10:50 PM   #3 (permalink)
Biplav's Avatar
no yaar its just got 1.1mb shared memory
and u sure it plays Mp3?
General
Network
GSM 900 / GSM 1800
Size
Dimensions
104 x 44 x 17 mm
Weight
83 g
Display
Type
STN, 65K colors
Size
128 x 128 pixels, 8 lines
- Downloadable wallpapers
Ringtones
Type
Polyphonic (16 channels)
Customization
Composer, download
Vibration
Yes
Phonebook
200 x 5 fields
Memory
Call records
15 dialed, 15 received, 15 missed calls
- 1.1 MB shared memory
- 20 calendar items
GPRS
Class 10 (4+1/3+2 slots)
Features
Data speed
32 - 48 kbps
Messaging
SMS, EMS, MMS
Clock
Yes
Alarm
Yes
Infrared port
No
Games
Yes - Space Ball, Submarine
Colors
- Java
- WAP 1.2.1
- eZi text (T9)
- Scheduler
- Calculator
- Calendar
- World clock
- Voice memo (20sec each)
"Try again, fail again, fail better" - Samuel Beckett
Biplav is offline
Old 07-09-2005, 03:14 AM   #4 (permalink)
drgrudge's Avatar
Ohh, my bad, I got confused with LG 1800. I edited my above post. By the way, its' cheaper than C230 also.
drgrudge is offline
Old 09-09-2005, 06:46 AM   #5 (permalink)
expertno.1's Avatar
go for LG G1600 the better option
coz its network speeds are really good than the samsung one
i have G3100 and compared samsmung c210 and found that g3100 had more internet speed and responding
so i suggest that LG's other models would also have good network speeds like the G1600
expertno.1 is offline
Old 10-09-2005, 01:07 PM   #6 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
Nope.. i dun agree!
i bout da sam c210
is cool
sleek
and SEXY as HELL
GO WITH IT
i assure u dat its gr8!!!!!!
aku is offline
Old 11-09-2005, 09:45 AM   #7 (permalink)
LG G1600
khin007 is offline
