Originally Posted by chelsea_roks
And where can I download the flash for arm 6...I found in gsmarena that acer liquid mini has arm 11 cpu...Is it wrong???
ARM v6 is the instruction set supported by the ARM11 processor. to support flash player officially ARM v7 instruction set is required which is only supported by processors based on ARM cortex.
try these:
Flash Player 11. if it doesn't work, try
Flash Player 10.3. first try the one for custom rom. if it doesn't work try the one for stock rom, though you may need to root.
