Old 01-01-2012, 05:42 PM   #1 (permalink)
Default Best mobile around Rs 12000
I am looking to buy a cellphone. My budget is around Rs. 12000.
I would prefer a cellphone with good camera, nice audio and android os.
Please suggest me Samsung cellphones.
My choice is Galaxy S and Galaxy Ace.
sk_sin28 is offline   Reply With Quote
Old 01-01-2012, 06:09 PM   #2 (permalink)
Dust in the Wind
Skud's Avatar
Default Re: Best mobile around Rs 12000
Galaxy SL (not S) is 18k, Ace is 14k.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is online now   Reply With Quote
Old 01-01-2012, 06:55 PM   #3 (permalink)
Would say try and avoid Ace. If you can spend a bit more get a Neo V and if you want to save a bit of cash look at Optimus Net.
Old 02-01-2012, 12:03 PM   #4 (permalink)
siddhipatel
Posts: n/a
Hello,
I would suggest you Samsung Galaxy Fit having android OS and 5MP camera. Another option for you is Samsung Galaxy Pop. Both these phones are in your budget and fulfills all your requirement.
Old 02-01-2012, 02:34 PM   #5 (permalink)
fit & pop comes with 240X320 resolution screen. this suites only budget 5k mobiles not android smartphones. ace comes with less than 300Mb ram. a serious let down.
Old 02-01-2012, 02:50 PM   #6 (permalink)
Game on !!!
anupam_pb's Avatar
Check Motorola Fire XT. It has 5MP camera, a decent config .
Also check out Sony Ericsson Xperia Mini. It has only 3" screen and is thick(15mm+)
Don't go for Ace !!
My PC config : Intel core i3 2.93 Ghz, 2 x 2GB DDR3 1333Mhz, Intel DH55TC, XFX Radeon 5670 1 GB GDDR5, Windows 7 Ultimate 64-bit, LG DVD writer, Corsair CX430W, SAMSUNG 17" LCD (4:3); Samsung Galaxy Y
anupam_pb is offline   Reply With Quote
Old 02-01-2012, 07:53 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Go for Moto Defy @ 14k
Moto Fire sucks (bad screen, laggy UI, bad input, poor camera)
comp@ddict is offline   Reply With Quote
Old 02-01-2012, 09:00 PM   #8 (permalink)
BMG ftw!!
d6bmg's Avatar
Go for Moto Defy @14K
Actually +1 for the previous post of mine. (prolonged caching by my browser)
d6bmg is offline   Reply With Quote
