Old 24-12-2011, 06:42 PM   #1 (permalink)
Default plz help regarding Samsung Captivate Glide
I looking to by Samsung Captivate Glide so i need suggestion regarding this should i go for it or not, because in hardware wise it's same to Samsung Galaxy S II (just 0.2GHz low processor and not full hd video recording). Samsung i927 Captivate Glide vs. Samsung I9100 Galaxy S II - GSMArena.com
plz reply guy's ASAP.
Amey408 is offline   Reply With Quote
Old 24-12-2011, 08:01 PM   #2 (permalink)
Default Re: plz help regarding Samsung Captivate Glide
Bit confused what kind of help you need.
Anyway. What will the type of useage scenario of the phone you buy.? Also do you plan to do photo graphy too? Give all the relevant info.
Old 24-12-2011, 08:31 PM   #3 (permalink)
Will Power
TheLetterD's Avatar
Its a little thicker than the S2
About 4mm
Also it has a Flimsy build quality
Besides it hasnt launched in India yet! Where do you plan to get it from?
Mark my words, Soon after the Zombie Apocalypse, The Apes WILL take over! :hyper:
Follow me @ http://twitter.com/ThaLetterD
TheLetterD is offline   Reply With Quote
Old 24-12-2011, 10:52 PM   #4 (permalink)
1 of all i get it on ebay for 10,600/- check this Samsung Captivate Glide Android Phone (AT&T) | eBay
And my big question is whether i will get ICS update for this (not a problem with custom ROM)
