Old 19-12-2011, 12:48 PM   #1 (permalink)
Exclamation mobile by 15000
i want to purchase a mobile..... an android one . i am bit confused
first i chose se w8 it was'nt so good
then i moved to htc wildfire ... resolution issue :
then i saw htc wildfire s .... again a mob with sluggish processor
then i saw se xperia mini ... i found it a too good phone
but again some issues like battery ,camera , some kind of key malfunctioning
now i m looking for htc explorer
Suggest me a good phone .....
i want a phone with good performance.... android ,,,, should have good connectivity.......especially for downloading.......
A good screen size
vinit is offline
Old 19-12-2011, 01:07 PM   #2 (permalink)
clmlbx's Avatar
Default Re: mobile by 15000
Less then 15k Defy and at 16K SE NEO V
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 19-12-2011, 02:06 PM   #3 (permalink)
Try Samsung Galaxy Ace S5830 : Rs 14,990. This is the best for me in that budget.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline
Old 19-12-2011, 02:27 PM   #4 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Avoid Samsung Ace... it sucks...
You have 3 choices
1. SE Neo V
2. Samsung Galaxy SL
3. Motorola Defy
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is online now
Old 19-12-2011, 02:40 PM   #5 (permalink)
Sony Erricson Neo V gets my vote
thetechfreak is offline
Old 19-12-2011, 02:55 PM   #6 (permalink)
its best for you only.
Sam is online now
Old 19-12-2011, 07:41 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
15.5k Sony Neo V available at ebay.in
comp@ddict is offline
Old 20-12-2011, 10:28 AM   #8 (permalink)
Explorer
aroraanant's Avatar
My vote also goes to Neo V
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline
Old 20-12-2011, 11:05 AM   #9 (permalink)
Master troll
red dragon's Avatar
@o.p,why are you looking for android?App?or anything else?
Macbook Pro 2010,Macbook Air 11"2011,Samsung Galaxy S2,Ipad2,Sennheiser IE7,IE8,Earsonic SM3:razz:,
red dragon is offline
Old 20-12-2011, 02:33 PM   #10 (permalink)
Hi vinit
See I am suggestion few best phone according to your budget and features..
Samsung Omnia W
Samsung Galaxy Ace
Nokia C6 01
Samsung Wave 2
Sony Ericsson Xperia Pro
HTC Wildfire S
Here the best phone will be Sony Ericsson Xperia Pro.
abhishek63 is offline
Old 21-12-2011, 09:20 PM   #11 (permalink)
127.0.0.1
mitraark's Avatar
Sony Erricson Neo V from me as well
Good screen , even though you may get some models screen s with larger than 3.7" ,this one is more . Good Battery , Camera , Looks excellent , so is UI , Sony Erricson .
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is online now
Old 23-12-2011, 12:20 PM   #12 (permalink)
i m not satisfied with ur suggestion........ i dont like neo v......
its like wastage of money .there u r getting only 3.7 inch screen that s it;
suggest some thing good
vinit is offline
Old 23-12-2011, 01:21 PM   #13 (permalink)
when there isn't anything better in your budget, then how can someone suggest anything else? If you feel that way, research on your own and buy.
You want to save money, get Motorola Defy but it won't get Ice Cream Sandwich update from Motorola.
ico is offline
Old 23-12-2011, 01:39 PM   #14 (permalink)
Well even if you buy iPhone 3gs you wont get a bigger screen. Rather a screen of 3.5 inch
need a bigger screen? Double your budget and get a Samsung Galaxy S2.
As you can probably see the Neo is the best you can get in your budget
Old 23-12-2011, 02:14 PM   #15 (permalink)
Arsenal Fan
arsenalfan001's Avatar
care to explain what is good?
Laptop: HP DV6 - 6140tx | i7-2630 | 8GB DDR3 | 500GB 5400rpm | 1GB DDR5 ATI 6770 | Cooler Master Ergostand | Microsoft Sidewinder X4
Mobile: Nokia X2-01 | Nokia 2700 | Nokia N79 | Xperia Arc
The Dennis Bergkamp - who along with a few others, made me a Gunner
arsenalfan001 is offline
Old 27-12-2011, 08:44 PM   #16 (permalink)
★★★-DREADLORD-★★★
Skynaveen's Avatar
I vote for Neo V
It is the best at that range.
Skynaveen is offline
Old 27-12-2011, 09:19 PM   #17 (permalink)
Master troll
red dragon's Avatar
Neo V is definitely the best option in your budget,if you can increase your budget by 4k,can go for LG o2.
Old 27-12-2011, 10:26 PM   #18 (permalink)
Locking the thread.
OP has disappeared and suggestions have been made.
ico is offline
