Old 17-12-2011, 07:57 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default DeActivate OutGoing International Calls & Sms
I want to block outgoing International calls & outgoing international sms on my Vodafone number.
Should I contact Vodaofone or use the handset settings ?
Charley is offline   Reply With Quote
Old 17-12-2011, 08:54 PM   #2 (permalink)
clmlbx's Avatar
Default Re: DeActivate OutGoing International Calls & Sms
their is two ways to do that but for both way you need to call Voda customer car
1. Call customer care and then ask for Call barring password and then block it from your mobile..(I believe everytime you change mobile you have to do this).. Never done this myself.
2. Block calls on your number itself so what ever phone you use. calls won't be possible..
IMO get Barring password do it your self so you have control so you can unlock it anytime you need without contacting Custome care..
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now   Reply With Quote
Old 19-12-2011, 07:15 PM   #3 (permalink)
Just Do It
Charley's Avatar
Below is the message from Vodafone
We would like to inform you that ISD call and SMS service is available in prepaid by default hence there is no procedure to block the ISD calls and SMS on your number.
