Old 10-12-2011, 02:00 PM   #1 (permalink)
shubh.s's Avatar
Default The best phone for 17k .
1. Budget?
17k
2. Display type and size?
Capacitive Touch screen , Bigger than 3 inches.
3. Form Factor? bar, slider, flip?
Bar
4. Preferred choice of brand?
Sony Ericsson / Samsung / HTC / Nokia
5. Preferred input method (QWERTY, touchscreen, numpad, touch-n-type).
Touchscreen
6. What camera option you want? Please specify need for flash, autofocus, front facing camera.
Front facing camera , auto focus, flash.
7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
Android
8. Preferred connectivity options (3G, Wifi etc)Please specify clearly.
3G , WiFi
9. Preferred applications (Flash, Swype, GPS, etc)?
Flash, GPS
10. Primary use of handset (multimedia, camera, mails, internet, gaming etc)?
Multimedia, Gaming
11. Any specific mobile phones in consideration?
Sony Ericsson Xperia Neo V
shubh.s is offline   Reply With Quote
Old 10-12-2011, 07:42 PM   #2 (permalink)
Will Power
TheLetterD's Avatar
Default Re: The best phone for 17k .
Neo V!!!
Though Check out LG Optimus Black/2X (if you can extend ur budget around 2.5-3K)/Galaxy S too.
IF you get the SE Arc for around 19K thats a pretty sweet deal too.
Mark my words, Soon after the Zombie Apocalypse, The Apes WILL take over! :hyper:
Follow me @ http://twitter.com/ThaLetterD
TheLetterD is offline   Reply With Quote
Old 10-12-2011, 08:10 PM   #3 (permalink)
Explorer
aroraanant's Avatar
LG OP2X is available at letsbuy for 19k. Dual Core phone with great specs
Though Neo V is also a very good phone for 15.5-16.5k
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
Old 10-12-2011, 08:26 PM   #4 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
iPhone 3GS
IDDQD IDKFA
Anorion is offline   Reply With Quote
Old 10-12-2011, 09:05 PM   #5 (permalink)
shubh.s's Avatar
Originally Posted by Anorion View Post
iPhone 3GS
I'm a big fan of Apple and would love to get the iPhone. But iPhone 3GS is pretty outdated. And moreover it seems iOS 5 makes the phone start lagging? BTW Any news on the Refurbished iPhone 4 ???
How's the Optimus 2X?
Old 11-12-2011, 11:38 AM   #6 (permalink)
I would strongly suggest you not to buy the over expensive 2 year old iphone..
It is a good phone but for the same price or even lower you can get far better phones.. get optimus 2x.. It has got huge dev support.. and will soon get ICS..
ujjwal321 is offline   Reply With Quote
Old 11-12-2011, 03:03 PM   #7 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
hmm investing in a smartphone is also an investment in the apps, buying a smartphone without worrying about which apps you need and will use is a lil bit like buying a dslr and not worrying about lenses... so its best to factor in the cost of apps in your budget
Older models have two benefits, they still rock because the new ecosystems are designed to work on as many phones as possible, and often on many platforms, and the older models still outperform their newer updates on many counts, the Samsung Galaxy S for example prolly is better for audio than all other smartphones available atm, so the thing that is still kicking it for droids at that pricepoint is - the Defy - plus you get a few grands saved up for really kickass apps
and about the iphone 3GS - well, Jonathan Ive, the guy who designed all the iphones as well as the iPhone 4 and the iPhone 4S still uses the 3GS, if anything it is in fact much more stable than the iPhone 4, and though there will be a few apps that wont work on it, (there already are one or two), its gonna be supported for some time now, and there are still the best high quality options Apple changed the gameplan of phones getting "outdated"... so stop looking at older phones as junk sigh I have to reiterate this point in every thread lol
dont go by the vital stats of the phone anymore, you can have full 3D MMORPGs running on the SE Arc or the iPod 2G, the technology is soo good that it eclipses what console networks have been able to achieve, mobile apps are the first to connect iStore, BB, Android and PC into one ecosystem... so its really a matter of how well and compact the code is written, so this choice is about which ecosystem has better app makers, not which manufacturer makes better phones... some publishers like EA cant help but turn out massive apps, but there are tons of others who use the resources economically
if you absolutely must have a new budget droid then go for one of the new xperia ones, they got their sensibilities right this time around and the apps run smooth as butter
IDDQD IDKFA
Old 11-12-2011, 03:38 PM   #8 (permalink)
clmlbx's Avatar
You can look out for refurbished Iphone 4 at 20K around. out of your budget but you are a fan..
In your budget nothing beats Neov.. it alternative or say competitors in that range are galaxy s and galaxy SL .. only if your top most priority is Screen Size.. well difference is of Just 0.3 but still .. IMO NeoV is best..
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline   Reply With Quote
Old 11-12-2011, 04:57 PM   #9 (permalink)
shubh.s's Avatar
Yea But any idea where the refurbished iPhone 4's are selling??
Yea well I need to check the reviews of Optimus 2X. Specs look awesome!
Old 11-12-2011, 10:12 PM   #10 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
refrub 3GS 15k
any outlet with the iPhone phones usually have the cheaper refurbd option as well
there is nothing special about the 2x, not saying its a bad phone but at least the Defy is water resistant lol...
Old 13-12-2011, 09:25 PM   #11 (permalink)
shubh.s's Avatar
Okay guys, refurbished iPhones arent available near my place, so have to decide between the Neo V and Optimus 2X. Is dual core a noticable performance upgrade ?? And is it worth the few extra grand??
Old 14-12-2011, 11:02 AM   #12 (permalink)
clmlbx's Avatar
if u r crossing budget then optimus 2x is good choice..
you can get refurbished iphone from airtel and also from aircel, enquire their and see what is time of availability perhaps you can wait
I am not a fan of iphone so IMO optimus 2x is better
Old 14-12-2011, 12:01 PM   #13 (permalink)
iDota
Sarath's Avatar
3GS doesn't have the death grip and was the last good looking iPhone I know of.
For your budget look at Neo V
Online Shopping guide - PART IIIPS3™ master guide
Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180 | | | Article/Discussion: PS3™ vs PC
Sarath is offline   Reply With Quote
Old 19-12-2011, 05:22 PM   #14 (permalink)
shubh.s's Avatar
Guys How about Galaxy R??? Its 20k now. LGO2x or SGR ?
Old 19-12-2011, 07:39 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Order LG Optimus 2X for 18k from ebay
comp@ddict is offline   Reply With Quote
