Old 04-12-2011, 02:43 AM   #1 (permalink)
Exclamation Android Phones under 6000!??!
Hey Digitians,
help me get an Android with a followin requisite of mine..
1. Android (obvious)
2. wifi
3. 3G ( could do away with)
4. 3.5 mm jack for music
5. Budget Rs. 6000 +/- 500
Cheers!
pagipunjabi is offline   Reply With Quote
Old 04-12-2011, 10:15 AM   #2 (permalink)
Default Re: Android Phones under 6000!??!
only option: samsung galaxy y if you want something usable. avoid all those 2.8"/resistive screen mobiles.
Sam is offline   Reply With Quote
Old 04-12-2011, 10:46 AM   #3 (permalink)
Thumbs up Re: Android Phones under 6000!??!
Olrite Galaxy Y is an option!!
how about LG Optimus Me P350 ??
Galaxy Apollo?? Is Apollo available in India...?
Old 04-12-2011, 03:39 PM   #4 (permalink)
Avoid the me. Get the Galaxy Y. better phone.
thetechfreak is online now   Reply With Quote
Old 04-12-2011, 05:53 PM   #5 (permalink)
me is overpriced. avoid.
apollo is galaxy 3. long discontinued. check Micromax A70 only if you want a camera & proper resolution. else y is better.
Old 05-12-2011, 10:01 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
Galaxy Y & MicroMax A70
Old 05-12-2011, 01:11 PM   #7 (permalink)
+1 to Samsung Galaxy Y. The best android phone in Rs.7,000/- If you can invest Rs.1,000/- more then go for it.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
Old 05-12-2011, 02:12 PM   #8 (permalink)
║ Green World ║
ofabhishek's Avatar
Galaxy Y
Buy Samsung Galaxy Y at Best Price in India - Also find Specifications, Photos, Features & Reviews
Use Coupon "LB5POFF" and get the phone around 6.5k
→SGRI9103 :reading:
http://www.thinkdigit.com/forum/mobi...y-r-i9103.html
↓↓ LG E2260V 21.5" Full HD LED
Check out how people replied to OP's query :rofl:
http://www.thinkdigit.com/forum/mobi...est-phone.html
ofabhishek is offline   Reply With Quote
Old 06-12-2011, 05:09 PM   #9 (permalink)
Are there any complains regarding Galaxy Y screen?
Old 08-12-2011, 12:12 AM   #10 (permalink)
Soumik's Avatar
For that budget, i dont think anything's better than Galaxy Y. You can go for it eyes closed. Unless you want to try out the A70... which also.. on paper, is a nice device.
Soumik is offline   Reply With Quote
Old 08-12-2011, 02:34 AM   #11 (permalink)
ALL I DO IS WIN !!
devx's Avatar
3 options for android in your budget :-
Samsung Galaxy Y -- 6.7k
Micromax A70 -- 7.5k
I-Ball Andi (Dual sim) -- 6.2k
Samsung Galaxy Y is the best amongst above., Micromax is really overpriced. , I-ball would be a good option if you want need a dual-sim phone.
devx is offline   Reply With Quote
