Old 03-12-2011, 02:47 PM   #1 (permalink)
Question phone within 7K
i want to buy a phone within 7k with a gud battery backup and 3G as most important features. brands prefered- nokia samsung sony.. (suggest if any other is better) touchscreen and OS will be an add-on!
plz help!
coolprincess is offline   Reply With Quote
Old 04-12-2011, 10:44 AM   #2 (permalink)
kbar1's Avatar
Default Re: phone within 7K
Samsung Galaxy Y - a good entry level Android phone.
kbar1 is offline   Reply With Quote
Old 06-12-2011, 10:04 AM   #3 (permalink)
android lover
kamal_saran's Avatar
hey bro increase your budget a bit and you can get a dell xcd35 aka zte blade. . It have 3.5 " screen with much higher resolution than other phones in 10k range and also have good community support it's for 8.5k on letsbuy , you might get it for low on street price
CM 7.2 RC0 (KANG) on ZTE blade. @787mhz governor ondemand......
kamal_saran is offline   Reply With Quote
