Old 01-12-2011, 01:10 PM   #1 (permalink)
amit3987's Avatar
Default Comparision between Galaxy S plus and Galaxy R
I am planning to purchase a new mobile in the coming days and am confused between the Galaxy R and the Galaxy S plus ?
From what I have read, I understand that Galaxy S plus is just an overclocked version of Galaxy S with an Amoled screen.. while the Galaxy R is the downgraded version of the SGSII...
Need comments on which one would be better in terms of performance (web browsing, some gaming, acting as a music player, etc.)
Also if there are any good alternatives to the above two in the range of 21-24 K..
Samsung Galaxy R | XPS L502X: i7-2630QM processor 2GHz | 15.6" FHD 1080p WLED display with TrueLife | 6GB DDR3 SDRAM | 2GB NVIDIA® GeForce® GT 540M | 500GB Hard Drive | 9 cell Battery | Backlit Keyboard
amit3987 is offline   Reply With Quote
Old 01-12-2011, 01:28 PM   #2 (permalink)
║ Green World ║
ofabhishek's Avatar
Default Re: Comparision between Galaxy S plus and Galaxy R
Galaxy R undoubtedly if u're ok with SC-LCD...
Yesterday the price of GR has been slashed by 2k at both LB & flipkart, now its available for only Rs. 21,899 at LB
→SGRI9103 :reading:
http://www.thinkdigit.com/forum/mobi...y-r-i9103.html
↓↓ LG E2260V 21.5" Full HD LED
Check out how people replied to OP's query :rofl:
http://www.thinkdigit.com/forum/mobi...est-phone.html
ofabhishek is offline   Reply With Quote
Old 01-12-2011, 03:07 PM   #3 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Preferably buy phones which have been released in multiple countries, especially the US. That way you can be assured of good community support and timely updates.
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 01-12-2011, 03:15 PM   #4 (permalink)
I will also say Galaxy R but you can have a comparison here.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
Old 01-12-2011, 04:16 PM   #5 (permalink)
dharmil007's Avatar
Comaprisiion between Galaxy R & Galaxy S Plus :-
Galaxy R over Galaxy S Plus
  • GyroScope Sensor
    1GB RAM vs 512mb
    Touchwiz 4.0 {though not sure}
    Dual-core 1GHz ARM Cortex-A9 processor, ULP GeForce GPU, Tegra 2 AP20H chipset
Galaxy S Plus over Galaxy R
  • Super AMOLED Screen vs SC-lCD
    higher ppi
    Single Core 1.4 GHz Scorpion processor, Adreno 205 GPU, Qualcomm MSM8255T Snapdragon
on the specs sheet, galaxy R looks more promising then Galaxy SL.
But u need to also check community support for both these fones.
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
dharmil007 is offline   Reply With Quote
Old 02-12-2011, 10:31 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
galaxy R is better option than galaxy S+
Old 02-12-2011, 01:16 PM   #7 (permalink)
amit3987's Avatar
I checked LB and FLipkart.. at both the places it is priced at 22,900..
If you could provide a link for the price you mentioned.. it would be great
  • Dual-core 1GHz ARM Cortex-A9 processor, ULP GeForce GPU, Tegra 2 AP20H chipset
  • Single Core 1.4 GHz Scorpion processor, Adreno 205 GPU, Qualcomm MSM8255T Snapdragon
Is there some site where they provide a comparision on the moblie CPU's and GPU's.. I dont want to spend 23k and end up with a phone.. which would come with some handicaps.. like not being able to play HD videos or latest games..
Is the Galaxy R correctly priced right now.. or can we expect some more correction ?? Had read somewhere that the Galaxy R should be priced at 20 K given its specs ...
Also.. any other suggestions for mobiles in this price range.. I saw that Xperia Arc too retails around 23K.... is it better than the one's mentioned above ??
Old 02-12-2011, 03:48 PM   #8 (permalink)
Just apply the coupon code "lb5poff" in Letsbuy.com. The price will be reduced by Rs. 1000
s_holmes is offline   Reply With Quote
Old 02-12-2011, 05:07 PM   #9 (permalink)
║ Green World ║
ofabhishek's Avatar
exactly... only this coupon is working nowadays in LB btw yesterday i came across an ebay link of Galaxy R selling only for 21490...... reduce further 5%(if u've coupon)
but that listing has ended now
→SGRI9103 :reading:
Old 03-12-2011, 02:35 AM   #10 (permalink)
Explorer
aroraanant's Avatar
If you need to choose among these two then Galaxy R is the one you should go for.
And Arc for 23k isn't worth,if it was available for 19-20k then it would be good.
You can also have a look at Desire S or Incredible S
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
