Old 29-11-2011, 07:20 PM   #1 (permalink)
masterkd's Avatar
Question Need a phone within 13k!!
1. Budget 13k
2. Display type and size?Capacitive Touch and screen as big as possible
3. Form Factor? bar, slider, flip?Bar
4. Preferred choice of brand?None
5. What camera option you want? no choice
6. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc). strictly android
7. Preferred connectivity options 3G n Wifi
8. Primary use of handset (multimedia, camera, mails, internet, gaming etc).multimedia,Internet
9. Any specific mobile phones in consideration? Motorola Defy is overbudget,was thinking about HTC wildfire S and Samsung Ace S5830
Anyway is Motorola service is good?
i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|DLink 2730U WiFi Router|Windows 7 X64
Samsung Galaxy Note :hyper:
Steam
masterkd is offline   Reply With Quote
Old 29-11-2011, 08:31 PM   #2 (permalink)
Default Re: Need a phone within 13k!!
also check Motorola Fire XT but remember moto is lame when it comes to updates. if update (ICS) is important, nothing beats HTC. but XT has front cam i think.
my pick is Ace. with Android, bigger screen the better. but has really less ram. gsmarena list it as only 280Mb.
Sam is offline   Reply With Quote
Old 30-11-2011, 02:40 AM   #3 (permalink)
the m0nk who sold his PC!
MatchBoxx's Avatar
Though screen size is small, Sony Ericsson Xperia Mini packs a punch!
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
MatchBoxx is offline   Reply With Quote
Old 30-11-2011, 08:17 AM   #4 (permalink)
Master troll
red dragon's Avatar
Try to up your budget slightly and get the NeoV.
Macbook Pro 2010,Macbook Air 11"2011,Samsung Galaxy S2,Ipad2,Sennheiser IE7,IE8,Earsonic SM3:razz:,
red dragon is offline   Reply With Quote
Old 30-11-2011, 11:26 AM   #5 (permalink)
Ready to help
I also wanted to ask EXACTLY the same question in the forums, then saw this and thought against creating a new thread
So, I did a lot of reading on the net and then (as everyone else) narrowed it down to HTC Wildfire S, Samsung Galaxy Ace, and Motorola Defy.
These are my views:
Wildfire S : It has only a 600 MHz processor! I really don't think it can handle heavy apps well.
Galaxy Ace : The screen resolution is low (480x320) as compared to others in the same price range. Also, the camera's video quality sucks.
Defy : Still on Android 2.2 (Froyo). Also, from user opinions, it doesn't have a great battery life.
As of now, I'm considering buying Defy, although it is the costliest among them (and a little over budget). But it seems like its worth it
akshat2112 is offline   Reply With Quote
Old 30-11-2011, 12:28 PM   #6 (permalink)
rated R
ritvij's Avatar
+1 to neoV but if you are okay with slider qwerty and small screen 3" then go for Sony mini pro.. great price and good hardware.. check ebay for the best deal or buy from letsbuy using the coupon code AMEXLB
Dell XPS 15 L501x.. ; iPod touch 3rd gen. 32 gb.. ; Samsung Monte.. ; BlackBerry curve 3g 9300.. ; iPhone 3gs 32gb.. ; Logetic mx518.. ; CoolerMaster notepal x2.. ; Seagate FreeAgent GoFlex 2 TB usb 3.0.. ; Transcend StoreJet 1 TB usb 3.0 portable.. ; iOmega eGo 500 GB usb 3.0.. ; Sony CyberShot HX9V.. ; Samsung UA40D5500.. ;
ritvij is online now   Reply With Quote
Old 30-11-2011, 01:00 PM   #7 (permalink)
Ready to help
Okay, apparently, I had missed the Neo V somehow. It looks really great!
Can anyone please help me with finding the cheapest 1? Its for 17000 on flipkart
Old 30-11-2011, 09:30 PM   #8 (permalink)
║ Green World ║
ofabhishek's Avatar
Use coupon "LB5POFF" on letsbuy and get 5% OFF.... i think its the cheapest at the moment.....
→SGRI9103 :reading:
http://www.thinkdigit.com/forum/mobi...y-r-i9103.html
↓↓ LG E2260V 21.5" Full HD LED
Check out how people replied to OP's query :rofl:
http://www.thinkdigit.com/forum/mobi...est-phone.html
ofabhishek is offline   Reply With Quote
Old 01-12-2011, 05:58 PM   #9 (permalink)
Explorer
aroraanant's Avatar
Defy is a good phone but quite an old now.
I would also suggest you to go for Neo V if you can extend your budget
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
Old 04-12-2011, 11:24 PM   #10 (permalink)
Talking Re: Need a phone within 13k!!
I also have the exact same question/dilemma, have been searching for the best deal below 13k for 2 weeks now. I've researched the 10-15k bracket THOROUGHLY (yes seriously thoroughly ) on the net and here's what I have so far.
in 10-13k, serious contenders would be xperia mini and samsung galaxy ace. that's it. wildfire s is seriously underpowered (why go for wildfire s when you have the new htc explorer, a very good and newer set with very similar specs at 9-10k?)
I was all for defy in the beginning too, but with just android 2.2 (unless you do the cyanogen mod thingy which i'm assuming you won't) it doesn't match up, esp with the prices of defy+ falling so low (abt 16k best price online now). defy+ is better but again for ~16k you have much better spec'd options like xperia neo V and xperia ray.
Anyways, I've boiled it down to two:
1) Xperia Mini ST15i (best price at the mo: 11k -@Timtara with coupon code YR2011)
this is my default choice at present. it has the best hardware in this range by far (1 GHz processor, 512MB ram, 320MB internal memory,decent 5MP cam, does 720p HD video, great screen pixel density of 192ppi with the bravia display engine {otherwise found on higher end SE models}).
very big bonus: is confirmed to be updated to android 4.0 ICS
only things going against it are the small screen (3 in) and somewhat drab battery life.
ofcourse there's the mini pro with the qwerty and front facing cam but i don't see the point of paying 2/2.5k extra for just that, esp when it makes the phone much thicker and heavier.
2) Galaxy Ace (best price at the mo: 11.6k- @Koovs with coupon code koovsocial3-but be quick with this one, may expire soon)
strong contender in this category, single biggest plus being the big 3.5 in screen (which is a gorilla glass display btw), and also better battery life wrt the mini/mini pro. looks similar to iphone 4.
But gets dragged down by older hardware. Has 800MHz processor, ~200MB RAM and somewhat similar ROM. also it's android 2.2 by default but i guess it can update to 2.3 maybe, but 4.0 is out of question
About other slightly higher range phones, there's the defy+ as i said @16k, not a bad choice, and there's the neo V and galaxy S at ~15.5k (koovs again, both great deals). sadly my budget is strictly 13k, so these are out of reach (atleast for now )
Hope this helps...
I've decided to wait till the christmas/new year week when i guess many new offers will be seen...but then some people are saying with the rupee getting weaker the price of cellphones may rise in the near future. this is really confusing, so guys please help me out here.... duh2: what do i do?
thegodsend is offline   Reply With Quote
Old 05-12-2011, 01:58 AM   #11 (permalink)
Explorer
aroraanant's Avatar
Xperia mini has a 3" display...And one not should go for an android phone with less than 3.5" display.
And if we talk about galaxy Ace then Defy is far better than it and it is not worth for 12k,it should be priced for 9k or so
Old 05-12-2011, 10:07 AM   #12 (permalink)
Everyone has their preferences...some people want a small but powerful device with all the android goodness, the xperia mini is perfect in this case. It does not sacrifice functionality in the least despite its diminutive size and makes the most of what it has to work with. It's all about what works for you.
Old 05-12-2011, 11:54 AM   #13 (permalink)
I'll suggest Samsung Galaxy Ace in that budget.
GPS: The best way to navigate safely and securely.:smile:
rajeevk is offline   Reply With Quote
