Old 02-09-2005, 04:50 PM   #1 (permalink)
Default converting videos to 3gp etc
i have se w800i
i want to convert mpeg,wav,etc to mobile format like 3gp
is there any software to do that
shivi4 is offline
Old 03-09-2005, 09:42 AM   #2 (permalink)
Nokia Multimedia Convertor will do the job. It's free but needs a registration at the Nokia Developer Forums (free too) before downloading.
http://www.forum.nokia.com/main/0,,034-63,00.html
For better quality and more control on bitrate try this free tool
http://www.videohelp.com/tools?tool=3GP_Converter
Here's a guide for PSP - http://peripherals.engadget.com/entry/1234000980024404/ - but you can adapt it for use on your phone by lowering the video res to 208x176 and a video bitrate of <160kbps and audio < 20kbps, <22khz.
-Keith
Keith Sebastian is offline
Old 03-09-2005, 05:55 PM   #3 (permalink)
can i have software on my phone to play
wav and other video files
instead of converrting it
shivi4 is offline
Old 04-09-2005, 08:47 AM   #4 (permalink)
As W800i is not Symbian, I don't think you can install stuff on it. Check you manual for formats supported by the default player.
Keith
Old 04-09-2005, 10:55 AM   #5 (permalink)
gxsaurav
Posts: n/a
Simply use Xilisoft video convertor, it can even convert from mpg VCDs to 3GP
for video use a bitrate of 128 kbps & for audio AMR Narroband, unless it's music, about 16 kbps 8 KHz stereo for video is enough
Old 08-09-2005, 02:12 PM   #6 (permalink)
mariner's Avatar
why dont u try imToo 3gp convertor? works like a breeze
mariner is offline
