Old 15-11-2011, 09:20 PM   #1 (permalink)
darnee's Avatar
Default Way to spend mobile balance
I have an old Reliance CDMA handset. Recently it developed a charging problem so I decided to replace it. I have applied for MNP to BSNL and there are around two days before my number gets ported.
Now here's the problem. I got around 50 Rs balance, which I want to use rather than letting it get lapsed. The battery is almost discharged and hence I've kept the mobile switched off. Now how do I use this 50 Rs?
I can't make 50 Rs worth calls or send messages because the battery will be long gone before that. I basically want to know some places where I can use my mobile balance as payment source. It can anything like donations, bidding, etc.
All suggestions are welcome and thanks in advance.
darnee is offline   Reply With Quote
Old 15-11-2011, 09:43 PM   #2 (permalink)
pulkitpopli2004's Avatar
Default Re: Way to spend mobile balance
1. download any game
2. send KBC message or any other polls or contests
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is offline   Reply With Quote
