Old 01-09-2005, 11:22 PM   #1 (permalink)
Self-Obsession
hittheswitch's Avatar
Default Boosting mp3 files output !!
I have a P900 and i'm not satisfied with the audio output.There is no rpoblem with the mobile phone, actually i want the output to be a bit higher.One of my friend also has a P900 and has a much better audio output ( Not in quality, but the volume output ). He is using a software to amplify the mp3's.I tried using the Gain function in many audio editing softwares to boost the audio.I've tried mp3 direct cut also but no use.Audio output increases with these softwares but the mp3 quality decreases.The places where there is heavy bass in the audio file completely loose clarity.
I want to know a software to boost the volume of mp3 files without loosing quality or to decrease the bass a bit.I'm thinking of using Sonic Sound forge.Do you think it'll help?
TIA
dirtydignity
I'm walking between mads,but whats the use i'm still the worst one.
hittheswitch is offline
Old 01-09-2005, 11:45 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
See this topic:
http://www.thinkdigit.com/forum/view...568&highlight=
Moved here
drgrudge is offline
Old 02-09-2005, 06:07 AM   #3 (permalink)
expertno.1's Avatar
this is very easy
get yamahas SSD decorator and increase the sound of midi file and transfer to your mobile
you could add +60 db to midi ffile using this softie
http://smaf-yamaha.com/tools/downloads.html
expertno.1 is offline
Old 02-09-2005, 01:19 PM   #4 (permalink)
Get OggPlayer for P900 - http://symbianoggplay.sourceforge.net/UIQ.html
Also be sure to read this before installing the latest version - http://symbianoggplay.sourceforge.net/history.html#V110
OggPlayer features a gain boost setting which is what you're looking for. To convert MP3 to OGG, use CDEX (free) or DBPowerAmp software.
EDIT: Just saw under "Missing features" that "Extra sound amplification" is not supported with this build. Tough luck. No harm trying though.
Keith
Keith Sebastian is offline
